Is there such a thing???????
Rick Snyder
Is there such a thing as a NON "twisting like pretzel" compressor air hose?? If so, what is the brand and where can you buy one! The one I'm using in the shop is solid rubber and not the vinyl coated type. The vinyl coated one does the same thing. Is there any secert to keeping them from twisting?
Thanks, Rick
Re: Is there such a thing???????
Yonak
You can roll it up on a reel, Rick. I find that works pretty well for me.
Gates
hennebury
Great Air hose.
http://www.gates.com/brochure.cfm?brochure=2714&location_id=3184
Coiling
Tom Dunlap
If the hose is the typical round type, not coiled, you have to coil it right to work out the twists or hockles.
As an arborist I've coiled miles of rope in my day. Now, though, most of my ropes get flaked into buckets or sacks, my coiling days are behind me.
When you coil rope, hose, extension cords or any long skinny things you need to take into account that the material has an inner and outer diameter to it's coil.
Take the end in your palm then let it drop down maybe 12-15". Now, make a coil and lay the first coil in your palm. But, the trick is to give a little twist or roll towards the long end of the hose. Do this each time you make a coil. If the coils don't lay into each other neatly make a bit more of a twist.
When you uncoil do it deliberately and uncoil, don't just flop the coil on the ground and pull an end. Roll out the hockles with some gentle flips and twists.
The easier solution is to buy a crank up reel for the hose. HF has some decent value hose coils.
Tom
Flexzilla
Paul Cates - Henderson, KY
While the Flexzilla hose gets mixed reviews on Amazon, I'm happy with mine. While it may "pretzel" some, it's not nearly as bad compared the the cheapo $10 hose that I used to have.
over-and-under coiling
GolfSteve in Calgary
First, Lee Valley had a special buy of fluorescent green extremely flexible air hose. The stuff is great. Don't know if it is still available.
Second, learn how to over-and-under coil, or flip coil. It is very easy and will prevent the hose from turning into a pretzel - basically every second coil is wrapped the opposite direction so there is no net twist in the hose. Here's a video example (sorry the guy is annoying):
http://www.youtube.com/watch?v=MziOBf60Kn0
For larger hoses eg. coiling up 200' of 1" diameter steam hose :-( I typically do what Tom Dunlap described, but I think flip coiling might work also.
Figure-Eight
John McGaw
I was taught in the olden days when studio TV cameras were the size of dorm refrigerators that figure-eight was the only way to handle the cables which were a good 1" in diameter containing fifty or more conductors and coaxial cables and which were not in the least amenable to twist. The downside to the figure-eight trick is that it takes up floor (or shelf in the case of smaller material) space but it will not twist and kink no matter what you do as long as you are consistent with it.
Addressing the original question *LINK*
Henry Higginbotham
The advice you're getting about keeping kinks out of hoses is certainly good, but you asked about a hose that won't kink in the first place. While that may not be 100% obtainable, you might get close.
I have a 1/4" x 25' hose that I bought at a show from the Grex folks (it's bright green). It has been the best I've encountered. It is labeled as being an Air Pro Contractor's Choice, made in U.S.A.
I did a little searching and found this one at the orange box. It's 1/4", but they probably have 3/8" as well. And if it doesn't do what you want, they'll probably take it back. I'd go to the store and look at one. Mine is fairly flexible, kind of slick feeling, ribbed, and has a barely visible braid.
I have one of the Lee Valley hoses someone mentioned, too, and I like it but it's nowhere near as kink-reisitant the Grex hose.
Air Hose
Clarification about the LV hose
Henry Higginbotham
The Lee Valley hose is fine as long as it's pressurized, and much better than conventional hoses. But the Grex (AirPro) doesn't kink even if not under pressure. If a kink is trying to form, when you pull on it, it just twists until there's no kink. A curly hose maybe, but no kink.
Flexzilla
The Lee Valley stuff was "Flexzilla" air hose. Feels like silicone. Stays very flexible in cold weather (I keep my garage around 5-10 deg C, or around 40-50 deg F) and the Flexzilla hose is very flexible. The old vinyl hose was quite stiff at those temperatures.
Re: Figure-Eight
TomD
If you had a long coil of band saw band and secured one end, then walked away with the other until it was straight, each coil would put one twist in the band. So conversely, if you have a completely untwisted hose, by the time you make it into a laid coil, you have one twist per loop.
I bought myself a very heavy contractors extension cord. Because it was awkwardly heavy I would toss it on the ground at the worksite, and grab one end and walk to the socket. Then at the end of use, I would grab it from I think the tool end, but maybe the wall and and coil it up, finishing by unplugging it. This accidentally was the perfect formula. When I hauled off one end, it put a coil in, and when I coiled it up, I got one twist back in, in the correct direction.
