Noticing cracks opening up in wood. Wanting to make tabletops from logs cut into disk fashion about 4" thick. Read somewhere there is a chemical used to stop wood from cracking. Will someone please enlighten me? Thanks in advance.
Polyethylene glycol - PEG. It was used by wood turners for a while; not sure if it's still popular.
It's very, very hard to keep disks of logs that include the pith from cracking; it's sometimes possible with small sections, but not so much with pieces big enough for table tops. As the wood dries out, the rings shrink differentially, and the cracks relieve the stress being created. If your design calls for big log sections, you might consider making a cut from the pith out to one edge while the wood's wet, to let the wood go its natural way, and make the resulting wedge-shaped crack a design feature - either open or, once the wood's thoroughly dried, filled in some way that will still allow wood movement.
You'd also want to control moisture escape from the end grain, so it happens slowly. Latex paint, for instance, will slow it down.
Some time ago a solution was suggested that I've never tried but it seems to make a lot of sense. After sharing this solution someone did write back and said that it worked.
Go and look at the cover of The Book in the previous post. See that 'pie' or crack? The solution is to mimic that and then fill it back in.
Cut slabs off above and below the one that you want to use. With a bandsaw cut a relief through from bark to pith just like in the picture. That should relieve the drying tensions. Now, the slab will be able to open up like PacMan. Look at the slabs that you cut above and below. Cut a relief in the same fashion but somewhere around 180 degrees away. When all of the slabs dry you can clean up the 'pie' faces in the keeper slab. Then go to one or the other slab and cut out a corresponding pie piece to fit the 'crack'. With some care and planning you should find that the growth increments line up and you'll only have a feint glue line.
PEG was tried by some woodturners, but was abandoned because of finish problems. Surface film finishes wouldn't adhere to PEG treated wood. With penetrating oil finishes, the PEG would bleed back out of the wood for years.
This is what you want. Those that say you have to live with the splitting aren't up to date with the technology. Not cheap and it takes time but you will amaze those that say it's impossible. The look on their face...priceless!
