Glue mishap. Repair salvage advice needed
Dave Huber
I suffered a partial calamity today.
I'm completing the bent arms on my Morris chair.
I glued both arms without incident using DAP Weldwood urea formaldehyde glue.
I glued the top lamination on last night. Just like before. I must have flubbed the mixing or spreading or something. The last 2 inches on the end of one arm did not bond. It is sprung.
The remainder of the lamination is intact. Bond seems good. Does not seem like it wants to pop off.
The surfaces look coated, but did not bond. Clamping seemed ok. just like before.
Getting the arm off is not an option now. It is screwed on under the last lamination.
This lamination approximately 1/8"
I need to spread some adhesive into the gap as far as I can go and reclamp.
I'm trying to figure the best choice for repair adhesive.
I'm Open to all advice!
More of the same glue?
Epoxy?
Gorilla glue?
Thanks!!
Dave
Re: Glue mishap. Repair salvage advice needed
Bob
Bob
At this point I think epoxy is you only option. Another good reason to use hyde glue
I never use Gorilla glue. IMO, it is one of the worst.
I usually would use Titebond original, II or III - but that's me. I can usually manage to infiltrate it into cracks with a shop vac fine nozzle and a syringe.
Keith Newton
Dave, I think I would go with the epoxy, but first, see of you can get some sandpaper in there to rough up the surface of the failed glue. Epoxy likes to have a mechanical tooth / texture to grab onto. You may be able to work it further into the back with floss, or something really thin.
Make sure you get it warm while mixing it, if your shop is cool this time of year, because it needs heat to kick.
Dave Bair
I wonder if your shop is too cold; Weldwood calls for 70º.
David Huber
I may have had a problem with temperature, I guess. shop gets into the lower 60s. Perhaps a mixing problem. Most of the surface appears intact, for better or worse.
I plan to clean the surfaces up with strips of sandpaper and get as much adhesive in as possible. The string/dental floss suggestion will likely be helpful.
Does anyone know from experience if the Urea Formaldehyde glue will stick to hardened UF glue?
Otherwise, I'm likely to mix up enough epoxy and go for it, I guess.
Thanks for the help!
Dave
Re: Glue mishap. Repair salvage CRISIS AVERRTED
David Huber
Whew.
Went down to shop to clean up joint and attempt fix.
I attribute problem to the fact that shop was 58 degrees when I went down. I did not think about it. Needs 70.
Once I started playing with the joint, I discovered that some work with a chisel and a paint scraper got most of the top lamination to pop off. I was able to sand the remaining off.
Dust is nasty. Thank goodness sander has good dust extraction.
Now to get my hands on another figured 1/8" piece and carry on!
Thanks.
Dave
