Floor Finishes
Floor Finishes
Floor Finishes
Jim Hoeller
I have installed about 1200 sq ft of hardwood floors (red oak) in a new house I had built and was going to use a water based sealer/finish. My concern is the lack of any tone in that material. I really like the look of boiled linseed oil on walnut, cherry, oak, etc and need to know if it can be top coated with a water based finish. The odor of linseed oil is not objectionable but the odor of oil based varnishes is. Please give me your thoughts. It is Winter here in the Missouri Ozarks and opening the windows may not be an option.
Thanks
Re: Floor Finishes
Bona  Mega
Water based to which you can add dye toner to get the look you want. I seem to remember that we used 1/2 tsp of med. brown TransTint per gallon in the second coat. Issue with any tinted finish is lap marks so you need to go light on the tint and use an extra coat for more color. We did 3 coats; sealer, toned, and clear top coat.
They also make an amber-tinted sealer which you then can clearcoat.
Re: Floor Finishes
Bona Amberseal
Andy Halterman: Nocturnal Pedaler
Bona makes a water based sealer with amber dye already in it. Amberseal definitely improves the look of water based finish but it still lacks all the warmth of oil based products.
Bona also makes a quick dry oil based sealer called DriFast. Normally it drys in about 3 hrs. A couple coats of that and a final coat with Mega is something we do often. Once Dirfast is dry enough to to scuff, you can use water based finish right on top of it.
Better living through chemistry.
Re: Floor Finishes
Re: Floor Finishes
Frank Grambo
Jim,
I like Bona also..( since open windows are not an option) whatever sealer you select use set a small, clean fan up to circulate the air. Don't aim it at the floor. The air is like a billion sponges taking the moisture out of the finish, if you don't rotate the sponges, it will stay wet foooorevvvverr.
Good Luck
Re: Floor Finishes
Rick L
Re: Bona Traffic
Rick L
Bona Traffic is a water based finish with a Catalyst Hardener. Most Durable Bona finish. It's of European Origin. Glitsa is a US Washington State based similar product if you are inclined to buy American.
Re: Floor Finishes
Re: Floor Finishes
james jacomb
I've been using a oil modified water based poly made by min wax, it inparts the warmth you seek and is easy to work with. Only place I have found it at in Mo, is Lowes. $50.00 a gal. you can also use trans tint with this if you want to coustomize.
Re: Floor Finishes
There you are!
Rod Peterson—Ormond Beach, FL
There have been a couple or three threads over the last couple of months that were screaming desperately for your expertise. I couldn't figure out how to summon you.
Rod
Re: Floor Finishes
Re: There you are!
If you get in a pinch, you could always try the batman signal.
Wood flooring isn't rocket surgery. Right tool for the right job, lots of ibuprofen for the back/knees and you've got it.
Andy Halterman
Realized that I forgot my signature tag line on the previous post in Hendersonville, NC
Re: Floor Finishes
Re: Floor Finishes
Jim Hoeller
Thanks to all who offered solutions.
