Found a name -- finally
Gary Smyth
several weeks ago there was an inquiry concerning the name of this joint (sorry, but I lost track of the thread). It is called a Hirth coupling (joint). It can also be called a face gear. Ta Da!
Re: Found a name -- finally
Dale Lenz
Dale Lenz
I can remember face gear! Thanks for the info.
Thanks, Gary!
Henry Higginbotham
I was the one wanting a name to search by. The other suggestion, "serrated locking plate," generated a few hits, but most were expensive-looking machined parts (one was some sort of replacement part for an antique machine gun). I was hoping for something mass-produced and affordable. No luck on that so far; maybe this will yield something.
Re: Thanks, Gary!
John McGaw
If you have a lathe with an indexing plate and are willing to make up a jig to hold a router perpendicular to the axis of the lathe such a joint could be made from hardwood pretty quickly. I made a set of turned boxes which have radial "v" grooves from center to edge on their lids and which will lock together perfectly. This wasn't my intention but it does work out that way. Turn some hard maple disks with the grooves and provide centered holes in each for a bolt and you will have your own homebrew Hirth couplings FWIW.
Re: Thanks, Gary!
Those are sold a great deal in the photo and lighting industry. You might check with Manfrotto who sells a lot of that stuff and see if they have just the joint pieces.
You might also look in http://www.reidsupply.com/?gclid=CMvg-bmL-rQCFQ0GnQodl2QAMQ
Manfrotto
Henry Higginbotham
The picture in my original post (and reposted above by Gary) is of some sort of Manfrotto gizmo, I believe. But where I've seen Manfrotto use it, it's always been cast into a specialty part.
I did check Reid, but came up empty. Perhaps my search terms could be better.
Thanks for the suggestions.
