Re: Plywood Box & Epoxy/Fiberglass
TomD
"Tom,Thanks for your reply. I could use help with a few questions. Is there some info availale that would show how to do the outside of the box with the epoxy/fiberglass?"
- You should always attempt to do as much of piece at once as you can. In this case it would be 5 sides. So you run your router bit, and round over the corners, you will need round overs about as round as a pencil or a dime. Depends on the drape of the material you are using. I would probably use something in the 4 oz area.
- So imagine a table top you have thrown a table cloth over. That is how you set up your box, and how you drop your cloth on it.
- You have 3 different type of corners to do. 1) the three edges to the table top, these the material just falls over; 2) the three vertical edges, these the material is cut back from, but you have the option of trimming one side back and folding the other over, keep all folds back from the corner. If you chose to cut back from these verticals, make some bias strip to cover them; 3) The 4 corners, these the material is cut back from, and you cut out at least 10 round pieces, half of about 4.5". and 3.5".
- After routing and sanding, you will have some rough spots and probably some holes. Do not assume the cloth will bridge anything. You have the option of patching the problem areas and working on them till they are perfect, then when all is dry and smooth, you glass. I prefer to jump right in and the instructions that follow will deal with that approach, as well.
- When you are ready to go, you make up some putty (bog), and some clear. You have a 2" chip brush and a squeegee on hand. You dab any areas you need to fill will light epoxy resin, then you smear on bog. Leave the bog a little high, as it will disolve in. Everything has to be done fast, so as to keep ahead of the cure.
- Drape the material like the aforementioned table cloth over the part. Cut out the verticals and the corners. start wetting out the cloth with epoxy and squee.. and move the epoxy around so it fully wets the top cloth. Never leave puddles to harden, always scrape back to the surface of the cloth, but having done so the epoxy will sink in, and you will need to add more and srape off over the cloth again.
Work epoxy over the the top edges and down the faces wetting the glass as you go, but be careful not to splash it all on the ground. The corners will dry out the worst, so keep wetting them with the brush, and push them over with the squee.
When eventually you get the cloth down and filled, pick up your bias strips and do the vertical edges, but do no go all the way up to the corners. You can use small amounts of bog to smooth out joint areas so the cloth will lay down better. once the vertical side corners are done, you do the corners with the circles. Patch bog under, around the edg of the cloth, and on the very corner. drop the circle over the corner.
There is a trick to orienting the corners, which consists of looking at the corner with your eye entered over it, the way you would do, if you were looking through a cube from corner to corner. The circle has the fibers of the cloth running 0/90 in it, place those fibers so the are centered over the faces, and not the edges that run from the corners. If you don't get it right, no problem, just offset the circle 60 degrees and try again.
Once the circles are in place, dab them down, and wet them with the end of the brush, alternating some painting strokes. Then immediately slap the second patch on.
" Also in order to cut down on weight what would you think about just doing the inside corners of the boxes interior?"
That will work fine, assuming you made the box strong enough, but as far as making the corners strong, it does not mater that you glass the inside of the bog, just the corners. And you can even then get away with just coving the inside corners, though glass is a big upgrade. Use bias cut strips. You cove with bog, then you put the cloth in. Do it all at once, and wet. Do not bog, then sand, then glass.
The method described is the "dry method". this does not seal the plywood before the glass is put on. This means the plywood can offgas into the job. So select a time to do this job when the temps are cooling, or stable, and the barometric pressure is relatively stable.
