sealing cracks in wood
Mark M.
I'm in the process of making tabletops and coffee tables from tree trunks. After roughly 5-6 months of cureing the top surfaces were sanded to 220 grit and cracks filled with spar varnish mixed with sawdust and acraglass in other cracks. Most of the cracks are less than 1/8". Then 4-5 coats of spar varnish was applied sanding between each coat. Surfaces were then compounded and waxed to a nice sheen. It's been roughly 5 weeks and I'm noticing high spots over the filled cracks where apparently the filler expanded and dried. How can this be prevented as not to happen after the customer aquires the item? Should epoxy be used instead of varnish? Thanks in advance.
