If you are familiar with the following vice, I would appreciate any advice you may have as to how I want to use it. I’m new to woodworking and I am in the process of building a work bench. I would like to use a vice given to me as a side vice, but it is out of the ordinary and I would hate to install it on a new table only to find it won’t work.
Specs on the vice are as follows. It is a Wilton cast iron vice, which appears to be designed as both a horizontal vice and a vertical vice, with the vertical portion being on either the left or right side of the vice, depending on which way it is rotated when installed on the table. It has a 1-inch center screw and two, 1-inch guide rods. The screw is “faster” than on the Veritas vice I intend to install on the end of the table. This vice has 4-turns per inch instead of five. The jaws are 7-inches wide (horizontally and vertically down one side) and 3-inches deep to the screw. There are 10-inches between the jaws, metal to metal.
This got major positive reviews from Consumer Reports some years back, because it held wood equally well horizontally and vertically (well, and probably at an angle, too).
I'd use it as a face vise. Most people mount the face vise at the end opposite their dominant hand (left end if you're right handed, right if you're left). One reason for doing this is that, as you edge-plane long boards, you'll be planing toward the vise, and the board will vibrate less. Another (in my opinion not terribly important) is that, if you need to set the plane down on the bench while working a board, you won't have to reach across your body to do it.
You should then mount this vise so that the vertical portion is toward inside of the bench - for instance, if you're mounting it on the left end, have the vertical portion to the right. This way, when you're using the vertical face (for cutting dovetails, for instance), you'll have the bench surface right there, handy to set tools on.
I like to mount a vise with its rear jaw flush, or just slightly proud of (sticking out from), the edge of the top, so that, when you're holding a long board in the vise, the edge of the top provides some lateral support. In figuring out what "flush" is, remember that your vise should have some facing on the metal jaws. Wood is the traditional material; for this vise, you might consider high-grade hardwood plywood (baltic birch, appleply or the like), if you can find a couple of small chunks cheaply. Another facing that's gotten popular in recent years is heavy, stiff leather, glued on. Don't use masonite/hardboard - I can testify the face of this material is too slick, and your boards will slide around.
I've got one of these, not yet mounted. I noticed that the mounting holes are a little small, and think it should probably be mounted next to a leg in such a way that you can use the mounting holes on both sides of the "L."
These are my opinions; there are endless ways to set up a bench, and you'll need to experiment to find out your best way.
I have the quick version. The 1/2 nut wore out in less than a year, could not get a replacement part. Hosed clamped the 1/2nut together and use it as a simple screw vise. If anyone know where I can get replacement parts I would appreciate hearing from you.
