M16 Blade Tensioning...
Derek Arita
It's been years since I used my M16 and I forgot how to tension the blade. I think it's a 154" blade and I have a tension gauge, but again, I forgot how to use it. Can anyone who has an M16 give me some advice?
Derek Arita
Re: M16 Blade Tensioning...
Bob
Are you talking about the MM16 from MiniMax? If so tension the blade by pushing on it with the blade support bar all the way up until it deflects 1/4" and stops with moderate pressure (until your finger nail starts to turn red) Maybe someone can explain it better but that's what I do and sometimes a quarter turn more.
Derek Arita
Yeah. It's a Mini Max MM16. Do you have the blade length?
Bob
It makes no difference how long it is the tension is the same for any blade is my understanding.
bob murphy
I have a 145'' blade on my MM16 and tension it as other posters have mentioned.
jcousins
i have the older generation mm16 - blade length is 147". i set the tension to 2800 or 2900 psi.
jerry
bob murphy
How are you measuring the tension?
jcousins
i have an iturra blade tensioning gauge.
jerry
NM: Thanks
