Yep....I have run MILES of trim through my table mounted MV12. Last Friday, it just stopped. No sparks, odor, "different" noises....nothing. It just stopped. I took it out and to my workbench and blew it out real good. Turned it on there and it worked. Took it back to the table.....nada.
Anybody got any suggestions as to what I should check. This router has been my "pet" for many many years. If I lose it....ok....but if I can save it I certainly want to.
Thanking you all in advance for your valued advice.
This may be a stupid question but did you blow a fuse on that circuit and the one at the bench is on another circuit? I'd check the voltage at the point you plug in the table setup. Maybe the outlet there is bad for another check. It sounds like it is not the motor but the circuit you are using.
After I blew it out, it worked once on my bench. I put it back in the table and it did not work. Hmmm....so I took it back to the bench and it didn't work.
Someone suggested power switch and brushes.
Can you provide some guideance on how to check those?
I had problems with mine years ago and it was the speed control unit. You can bypass that and try it. if it works , then that's your problem. I just ran mine for the past few years without the speed control, it wasn't worth replacing it, and i have many other routers anyway.
Another possibility is the cord. Cords often fail when in one position because the break in the wire opens up, but work in another because the break closes and, even though the electricity is arcing across a gap, it's at least moving.
All of the following is done with the router unplugged.
Brushes are pretty simple: remove the brush caps (from the photos I've found online, they should be the black circles with screwdriver slots facing you as you hold it and directly opposite that point), remove the brushes, and examine them. If they're very short, you need new ones, which you can get from a number of places (I like ereplacementparts.com, but there are lots of sources).
For the cord and switch, you need a multitester, available in a number of models at your local hardware store, Radio Shack, or big boxy store. I tend to step up one level from the cheapest, but I don't buy the fancy-dan ones. Maybe it's because I do something stupid and fry one every couple of years.
Figure out how to open up the switch and cord connection (if you've got the owner's manual, it may have a parts diagram that will help here), then use the resistance or continuity setting on the multitester to check switch function and the cord. You want to show continuity (that is, a continuous connection: low or zero resistance, or, if you get a multitester with a "squeal when there's continuity" setting, one of my favorite settings, a noise) through the switch when it's on. Wiggle the cord around and test each wire for continuity.
If you do find it's the switch, it's not a bad idea to replace the cord while you're at it.
The brushes are easily available online and will probably cost around $5. One would hope that it is the brushes since the switch is more like $20 and the speed controller is $110. If either of these failed on my MV12 (mine is about as old) I'd bypass them entirely. The former is no problem since I switch external to the router table but the latter would be a PITA since it would preclude larger-diameter bits.
WOW.....IF the router did come with an extra set of brushes....you hit the nail on the head as to where they could possibly be!
As for bypassing the speed control or on/off switch (I already control on/off with a wall mounted typical on/off switch in the router table).....can anybody give me a 10 minute "tutorial" as to how to bypass those switches?
Wish I could help. I hope you figure it out...I have been using mine since around '98 or so? Great machine. The only trouble I ever had was the loose collet. Fortunately, that was easy to fix. There are so many good options out there today, I hope mine keeps going because I'd hate to have to study them all and pick one!
