A55 Smoothing Plane
Paint for a fireplace mantle.
Stuart Hough
I need to modify my fireplace mantle by adding a new, wider top. What type of paint should I use for it? I have painted several things over the years and have had the problem of things sticking to the paint, even months later. What do you suggest?
Re: Paint for a fireplace mantle.
I prefer using eggshell or satin finish and waiting days or a week before I put anything on the paint.
You can use a top coat of something quick drying and compatible with your paint. Polycrylic may work for you.
Jason Roehl in Lafayette, IN
Blocking
...is the industry term. Typically, what you want to use is a true acrylic enamel, not just any "latex" off the shelf of the borg. Enamels will tend to cost quite a bit more than standard "wall and trim" paint.
Another option would be to topcoat the paint with a clear acrylic topcoat (waterborne poly). Floor poly is much more durable and scuff resistant, making the likelihood of future repairs (harder to do with a clear coat) less.
Jason
Bob
Bob
If its painted as mine was, just semi-gloss or gloss would be fine. The reason being you can clean it with soap and water. Just don't use the cheap stuff.
