Supertune your Tablesaw
Jim B
I have a General 350 TS purchased in 2004. When I first purchased the saw I checked the blade alignment at 90 degrees (0.003) and at 45 degree (0.012). I was not happy with the 45 degree angle but I figured it was good enough. I am in the process of making an Arts and Crafts Limbert table which calls for tapered 45 degree cuts...I figured now was the time to tune up my TS...I rechecked the alignment and it was now at 0.005 at 90 and 0.015 at 45. I tried to realign the blade but noticed that one bolt was hanging my ability to line things up. So I removed the top and elongated one of the holes that connects the table top to the cabinet. This made a huge difference. I could now align the top without too much problem...of course I had to sneak up on the settings tweaking each bolt a little at a time but got it set up to 0.002...cool...now on to the 45 degree angle. I rechecked and now it was out by 0.010 not awful but not good enough.
I remember reading an article in American Woodworker Magazine about setting up your TS blade at 45 degrees so I plunked in my fairly new DVD with all of the AWW magazines from 1985-2010 and found the article in AWW #43 February 1995. I followed along and used the author, Tom Borroughs, calculations to figure how thick the shims should be and where they should be placed. Anyway the calculation came to adding a 0.024 thick shim between the two rear mounting bolts and table...put them in...redid the alignment at 90 degrees to within 0.015 and then measured at 45 degrees...0.002...acceptable in my book!
Jim
