Re: Spraying Polyurethane
Jim DeLaney, Austintown, Ohio
I've sprayed it with an HVLP gun, 1.5mm cap & needle, and about 12 psi at the tip. I sprayed it straight from the can - not thinned.
That said, I prefer to spray WB lacquer (General Finished "Enduro" or Target "EM6000") instead of poly. Easier to spray, and it 'burns in' to previous coats, making repairs later easier to do.
For greater durability than either poly or lacquer, I use ML Campbell "Agualente" Pre-Cat lacquer.
The lacquers all work well thru a 1.2mm cap at about 10~12 psi.
