200+ woodworking book reviews
Loosening glue joints
Mark
I turned a 4poster bed for my daughter many years ago. Twin size and now she wants to convert to a double sized mattress, so I have to replace the head and foot board with new wider ones.
The head board is mortised into the post in two places, two 3 inch tenons into each post with and open arch between them.. I could easily cut them out and then re mortise or clean out but was hoping I might be able to dis assemble without damaging the current head and foot boards
Any tips for lessening those joints ...they we originally glued up using yellow carpenter glue 12+ yearsd ago.
Re: Loosening glue joints
Howard Acheson
Standard first generation (not waterproof) can generally be disassembled with hot water and vinegar. Wet a rag and wrap it around the joint. Then direct an infrared heat lamp at the rag and l let it "cook" for 15-30 minutes. Do not get it so hot that it materially damages the finish. Use heavy padded mallet and give the joint a hard rap to slide open the joint.
Be sure to completely clean up the mortise before assembling the new joint.
easy
It is a myth that yellow glue is not easily reversed. Drill the mortise almost but not all the way through at slightly over needle diameter. You will need a needle (ball inflation needle is grand), a steam source (pressure cooker works) and tubing (get at Lowes) to connect pressure cooker nipple to needle. Insert needle and steam. About 10-15 min may be necessary. Also you will need to rig some arrangement to apply steady Declamping force. When the joint gets heated and soggy it will pull apart with moderate force depending on how tight the mortise was cut.
Re: easy
Lee Schierer McKean, PA
Don't you also need an exit hole so the steam can actually get into the head space?
Lee
one hole
The antique fixer who taught me this procedure used one hole and that is what I have used. If using X-ray vision or good luck one can align the hole so that it comes out near the bottom of the mortise it will loosen faster.
Unclear how to implement the two hole procedure works. Please clarify the hole placement as it may be better.
Water and warm promptly softens unmodified poly(vinyl acetate) adhesives (regular white and yellow glue). This property can be used to remove the dried glue from clothes and tools, as well as reversing joints.
