FWW Shaker Stool Question
Steve Kirincich
I am in the process of building the Shaker stool described by Christian Becksvoort in the February issue of FWW, and I noticed that he uses wedges to secure the through mortise and tenon joinery. Is he able to safely orient the wedges parallel to the grain of the top board because white pine is soft and somewhat forgiving of what would normally be a problematic situation? Thanks.
Steve
Re: FWW Shaker Stool Question
Think about the bottom piece as opposed to the top piece. The uprights are being spread by the wedges. Personally, I usually cut a saw kerf in which I insert the wedge. That usually takes off a bit of the pressure.
But you are also correct in that the white pine (or poplar) seats can take a bit of pressure. Don't use very thick wedges and have a reasonable saw kerf.
paul in AZ
Not sure if this answers your question but many years ago I made wedged through mortises in poplar. I debated the direction of the cut and finally put it in from corner to corner, using a slender wedge tapped in rather gently.
Thirty years and holding.
