matching patina's
james jacomb
Well after installing my upper kitchen cabinets about 20 years ago minus the doors I'm finally getting around to the base units. So the cabs are knotty pine and have a nice patina, the bases are the same products but without the benefit of 20 yrs uv light. So I'm trying to figure out what to do to help blend the color. I'm finishing with an oil modified water based poly. I'm leaning towards blending Trans Tint dyes in the poly for a base coat then top off with untinted. This seems like a safe alternative to mixing oil based stains with poly top coats and then there is preconditioning pine if you do that. I have not worked with water based stains yet and i'm not sure I would find an exact match with out blending. I have looked into water modified amber shellac which would need to be top coated with a converstion varnish. I also looked at the water based lacquer but it is not recommended over the wm shellac. So, there seems to be many choices out there, I started this project with water based poly and I think it prudent to finish with it and less complicated. Any thoughts or suggestions are welcome.
I do worry that twenty years from now the new and old work might not match, but will I see it?
