Name of the Grid
Tom Rex in TX
To build a sturdy top of a work bench some men build a honeycomb like grid by standing 2 X 4's on edge then put a top on top of the grid.
What is that grid called?
Name of the Grid
Tom Rex in TX
Sounds like a torsion box?
Tony-Memphis
Not sure what you call the grid specificaly though.
Tony
Re: Sounds like a torsion box?
Tom Rex in TX
That's it. THANKS
Not exactly,
Keith Newton
A torsion box has a frame around the outside, with a grid in the middle, and a skin on both sides. The inside parts are usually light weight, and the strength comes from the contact with the thickness from top to bottom.
You didn't mention a bottom plywood.
Re: Name of the Grid
don stephan
Your grid could be 3/4" of even 1/2" thick material on edge, every two inches, rather than 2x4's. If the top and bottom are even good quality 1/4" thick ply likely you'll be surprised how rigid the torsion box is. Lay a loose piece of 1/2" or 3/4" ply on top for a work surface, and replace when too badly chewed up. This would be one of many possible alternatives.
Stuart Hough
Aside from the name "grid", I have always heard it referred to as the "eggcrate".
Re: Not exactly,
Alan in Little Washington (NC)
Torsion boxes have many applications and the structure should be adjusted to meet the specific needs and use. In general they don't need edges unless they will be clamped. A torsion box workbench or assembly table should have an edge and if it must hold up to hammering, etc. the top skin should be thicker and tough, the bottom can be thin.
The interior structure is called a shear web. The strength comes from the height of the shear web, not its thickness, and the strength (resistance to stretching) of the skins along their surfaces. The shear web just holds the skins apart so can be made from thin material as long as you get a decent bond to the skins.
The spacing of the shear web (grid) depends on the stiffness of the top skin and what point loads you might apply to it. There is a tradeoff between spacing and skin thickness.
I wrote a two part article that was published in American Woodworker a few years ago that showed how to make a torsion box assembly table.
Re: Not exactly,
TomD
I have made a bunch of these for use around the shop. I use 3/8" strips of ply ripped from the sheet. I use a dado to rip tight slots in the edge of a 2x4. One does not have to space them too closely, on a boat beam the spread might be 12 inches, and that would support walking loads. I forget what I use but probalby no nearer than every six inches. I'm sure to some extent the number of cross pieces was factored in. The pieces go across the short distance. I do not use a sheet on the bottom though that dynamites the overall strength, but for most stuff is has not proven necessary. In assembly I just guy ans stapple the ends into the 2x4s, and later I check the heights of the pieces, and then put glue everywhere and use narrow crown staples to hold it all together.
The beams on this trimaran are the shear webs are the vertical sides of the beam, and are 4mm ply the top is 8mm ply, and there are periodic bulkheads. Beams are heavily loaded, they take walking loads, rigging loads, righting moments, and just general crashing about.
https://www.youtube.com/watch?v=Z-lgC4WBk6Y
