Planning hard-to-reach Plywood
Ron Milan
PROBLEM: Need to plane off 1/8” from ¾” plywood sheet in a constrained situation.
SITUATION: We have a triangular kitchen table that has three cherry wood sides that are sandwiched around ¾” plywood making a triangle table. The top of the three border sides are ¼” higher than the plywood. One quarter (¼) inch tiles have been inlaid in the triangle eating table. The ¼” titles have been removed and a 3/8” title is now to be inlaid. (Because of the construction, the screws, the glue, and the fit, the cherry wood cannot be disassembled to insert a 5/8” plywood sheet.)
PLEASE ADVISE: Can you advise on how to take off 1/8” of the plywood in the middle space, the tight confining corners, and around the 1/8” cherry wood edges without nicking? Can an amateur do this?
Thank you
