OT - Large caulk tube sources?
We need to caulk between the tilt slabs on the outside of our playhouse. I'd rather not go up and down the ladder a bunch of times. I would like to get the largest tubes of caulk possible - the 10.1 oz tubes aren't big enough. I would like 20-30 oz size. I can get a caulking gun that will handle the big tubes - but the local hardware store only sells the caulk in the small tubes (and construction adhesive in large tubes). The people at the hardware store aren't aware of any brands and their distributors don't seem to carry what I would like.
I've found one manufacturer of caulk in large tubes (Sashco) - that sells caulk for log homes. They may be able to help me. I would like other sources just in case.
Re: OT - Large caulk tube sources?
john Veerkamp
Dap used to make caulk in big tubes. Been a couple of years since I worked in farm & home store. If you can't find them, haul half a dozen regular tubes in a bag and hook to a rung.
Caulk Guns Are Cheap
Dave's Not Here
Buy a couple extra guns, load them and take them up the ladder with you.
Jason Waters
When working on a ladder, and reaching, I'd prefer the smaller lighter one, it would be easier to control. I'd just switch tubes, and drop ones to the ground when I was done with one.
The problem w/ small tubes...
is that the caulk bead is wide. In some instances up to 1" (or at least 3/4"). I'm going to go up on a ladder, cut the bad caulk out (in places) and caulk as needed.
I can see using a large tube. I can cut the opening wide and easily do a 1' long strip of 1" W caulk (or longer). That would take me at least one tube of caulk.
I've visually inspected the exterior of the building. By my rough calculations, I would need 10 large tube (or 30 small tubes) of caulk. I've actually found empty tubes for sale - but I'd have to fill them. Maybe I should buy a pail of caulk and do that.
I just figured if the building was originally caulked - they had large caulk tubes or something similar.
Jason Roehl in Lafayette, IN
Re: The problem w/ small tubes...
One inch gaps? That's well beyond the limitations of most caulks out there today--and well into the territory of chinking (probably why you came up with Sashco for log cabins).
Even for gaps 1/4"-1/2", it's good to use a closed-cell foam backer rod. This needs to be thick enough that it's compressed slightly in the gap, and pushed in just deep enough that when caulked over, the resulting cross-section of the caulk is an hour glass shape. The hour glass cross-section is important for caulk--the wider "bases" provide the necessary adhesion, and the narrow center section allows for movement/stretching/flex. Just gooping a bunch of caulk into a gap will result in stiff caulk that pulls away from one side or the other in a short time because it's thickest in the middle of the cross-section, and not much relative contact area on either side results in poor adhesion.
I'd work on finding a way to reduce the gap before slathering on a bunch of caulk.
Jason
Jason Waters
I agree 1 inch seems too much gap. What exactly is this for?
20 oz. sausage gun, maybe? *LINK*
Henry Higginbotham
A manual sausage gun costs more than a standard caulking gun ($30-50 usually), but you might be able to rent something like an 18V cordless powered model, depending on where you are. And you might find a more industrial-strength selection of caulk in the sausage packs. Just a wild idea.
Milwaukee Sausage Gun
Tilt up buildings are still being built. The local Home Depots are built that way. Perhaps you could find a contractor that builds tilt up buildings and get some advice.
Swimming pool decks (concrete ones) use caulking like you mention. Find a local pool builder and get some advice.
Find a local commercial caulking contractor and get some advice. There really are contractors that specialize in caulking.
Thiokol and Pecora used to be the top brands of commercial caulking. Check with them.
The advice you got on using backer rod was excellent. Be sure you understand it and follow the protocol.
Tilt slab constrution
The slabs were originally caulked. The caulk has pulled away in some places.
Re: Tilt slab constrution
Robert Hayward
The tilt slab buildings I have worked on were caulked with a two part urethane caulk, if I am remembering correctly. Made to fill those enormous gaps. When cured it was as tough as tire rubber. A one inch diameter piece of if could not be stretched in two with bare hands.
Bob
Re: OT - Large caulk tube sources? *LINK*
Bob Entwisle in NJ
Hi JL,
I googled "tilt up building Caulk" and came up with this and a bunch of other links.
Might give you some more guidance and info on the task at hand.
Bob in NJ
http://www.concreteconstruction.net/caulks-adhesives-and-sealants/sealing-joints-in-tilt-up-panels.aspx
Exactly my point.
If you can't stretch a 1" diameter bead of it by hand, it won't stretch to accommodate the movement of the gap its filling--more than likely the force needed to stretch it per unit of length will exceed the total adhesion per unit of length. This is why the backer rod and achieving the hour glass cross section is so important, and much more so as the gaps being filled get bigger.
Jason
Jason Waters
Here is a U-tube where they are caulking the frost wall to a basement floor with a large crack. I think this is similar to what you need.
http://www.youtube.com/watch?v=IPoYgNkzRIg
Tilt Slab, I was thinking something else, but it's poured on the ground and lifted in place. A lot of shopping centers and stores are built like that now.
Maybe a trip to Sherwin Williams is in order:
http://www.sherwin-williams.com/architects-specifiers-designers/products/catalog/shelf/equipment-supplies/caulks-sealants-caulking-tools/caulks-sealants/?Nao=0&N=1108637827
This looks suitable, but they probably have a sales rep that could help you.
http://www.sherwin-williams.com/architects-specifiers-designers/products/catalog/stampede1-polyurethane-sealant/?referringCategory=equipment-supplies/caulks-sealants-caulking-tools/caulks-sealants/
I am not recommending these products, but once I realized what you were caulking, I think you need to go somewhere other than the local hardware store. No, Sherwin Williams will not be cheap for sure, but this is not where you want to skimp. You need a specialized product, and probably fresh stock as these sealants dry in the tube over time (ie, I wouldn't buy it from somewhere I thought it was sitting on the shelf for 10 years, and yes that can happen in stores). Who built the place? They might can recommended where to get the product that was used.
Anyway, just some thoughts
james jacomb
We use different construction supply companies for the products you need. Carters Waters is one or Construction anchors is another, usually a sonneborn product is used. These two companies are in Kansas City, not sure of your local, but they are just distributers. Google sonneborn, find a dist, call them and let them know your needs and they will match your with the correct product for the application plus all the tech specs and application specs.
