Super Bowed Accufence...
Derek Arita
OK...so I finally broke out my 4 year old PM Accufence that came with my PM2000. I've been using a Beis, but thought I would try the Accufence out. I put a straight edge along the fence face and found it was bowed in a lot...like about 1/16 or more. I just got off the phone with PM and Bob tells me that it's no problem and that the Accufence is made to be shimmed out to flat, even that much. He said just use layers of masking tape to shim it out.
Has anyone had experience with the Accufence? Is that much bow an issue and can it really be shimmed out that much?
Re: Super Bowed Accufence...
John in NM
Isn't it a Biesmeyer clone? Steel rectangular tube with applied sides of some kind?
In general, I would expect any extrusion to be a lot straighter than that, but from a functional point of view there is no reason that shimming it wouldn't work fine. I would use cut up aluminum can rather than tape myself, or maybe shim stock since I have some.
I've never had to take the sides off one of those, so I don't know how they are attached.
Accu.... really?
Re: Accu.... really?
Derek Arita
Yeah. The ends of the extrusion have plates welded on. It seems like when the holes were drilled down the face of the extrusion to mount the plastic fence face, the pressure from the drill press slightly deformed the extrusion. The reinforced ends did not deform, thus the bow in the center. Maybe grinding some of material on the ends will bring it down close enough to more easily shim the center.
Mark Hennebury
Got a photo?
Kneale Brownson
Kneale Brownson
I'd just take off the plastic facing and shim behind it.
Derek Arita
Yeah...that's what I'll do, but it will take a lot of shim to bring it flat...almost end to end and thick too.
Tony-Memphis
Mine is about the same vintage and it is pretty straight. Honestly, I've never put a straightedge against it, but I have been using it all along and never noticed any issues. Now I'll have to pull out the Starrett and check it!
Tony
Derek Arita
Tony,
Let me know if you see any daylight.
Derek Arita
So, I think I figured out what is going on with the bowed fence. I took the fence face off and put a straight edge along the extrusion. I found that it's really pretty straight. I then put the face back on and put the straight edge along the face. I found that the ends of the face are lifting up the straight edge, causing the bow. It goes from end to end.
The face attaches to the extrusion with T bolts in slots that are in the UMHW. As the nut on the ends tightens, it deforms the sides of the slots and forces the end of the UMHW to rise up. Loosening the nut only transfers the rise to the next bolt in, so it doesn't help. Hope this explanation makes sense.
I'm thinking about not using those end bolts and drilling/countersinking my own holes on the ends that go straight thru, with a round washer head screw to help stop any deformation of the UMHW. Short of planing the ends of the face flat, that's about all I can think of doing.
