Veritas - Innovation in Tools
Lumber dimensional defect definitions
I find that "crook" is not commonly known and used to describe distorted boards. It is often incorrectly called bow. There definitions will help us communicate better.
Bow- a deviation in a direction perpendicular to the flat face, from a straight line from end to end of the piece.
Crook- a deviation in a direction perpendicular to the edge, from a straight line from end to end of the piece.
Cup- a distortion of a board in which there is a deviation flatwise from a straight line across the width of the board.
Twist- a distortion resulting from turning or winding of the edges of a board so that the four corners of any face are no longer in the same plane..
Re: Lumber dimensional defect definitions
del schisler
I find that "crook" is not commonly known and used to describe distorted boards ,, Maybe the one that is selling the board's ???
Dale Lenz
Dale Lenz
When the pith is left in the board on the edge side you often get this (, a crook, due to longatutual(sp) movement.
more common....
It comes from drying a stack that was not stacked level , or, a stack made from lumber sawed off a head saw out of whack which will then cut boards that are thin on the ends, or deflection of the board along its length due to a large knot in the piece.
that is the problem
Although this term is the National Hardwood Lumber Association approved term for this deviation from straight many people don't know and use it, which leads to confusion. On the other forum someone was explaining how to use the drying tension in lumber to straighten crook. Because they didn't call it crook some thought it was cup or bow that was being discussed. Precise terms leads to clearer communication.
Dale Lenz
I agree...
Dale Lenz
all that you said makes good sense. When ever I have a log quarter-sawn w/ a bandsaw, sometimes the pith gets left in a board near the boards edge and I get the " ( " shape while drying. My lumber stack is pretty flat and level. Normally, I need to lift up the tin some how to provide drainage.
why the pith crooks, etc
The first wood made by a sprouted tree has a different cell structure than mature wood. This type of cell is made till the tree reaches significant height, and may be around 4" of the tree diameter, more or less. It shrinks more when drying. So, if you have this shrinky wood on one side of a board and normal mature wood on the other, a crook will result. For this reason the center of trees are normally "boxed" out and sawed up for pallet lumber or other junk applications.
Dale Lenz
Once again, I agree...
Dale Lenz
but the way I ask the bandsawyer to quarter saw my log/logs the "heart" is quartered also and if the pith is left on the board's edge you get longitudinal shrinkage, that's seems to cause the " ( " shape. If sawing for grade, yes, "box the heart" and toss or use for as you said other junk stuff. Obviously, if I think about it, I’ll have the sawyer rip the pith out of the board.
Think I have read some research that early pruning of trees May reduce the volume of juvenile wood, the cause of longitudinal shrinkage.
As I understand it
DizD
juvenile wood is formed in the portion of the tree that has limbs. As the limbs are shed, you get transition to cells with thicker walls. So, even tall trees will have juvenile wood in the crown portion.
Thanks to all for the info in this thread.
Stuart Hough
That cleared up some questions I had. I will now be better prepared when I dive into the next woodpile!
