scroll saw question
scroll saw question
scroll saw question
Kristin
I decorate different wooden items and am looking to get a scroll saw to start cutting my own wooden shapes and letters...I thought there was a scroll saw that would allow me to lift the blade and put it down in the center (say for a letter O) to cut the center out without having to make a cut in the actual letter... is there a saw out there that is not very expensive for me to start with?
Re: scroll saw question
Jesse Cloud
Welcome to scrolling - hope you enjoy it.
Actually, any scroll saw can do what you ask. Simply drill a small hole in the center of the "D" and the tiny blade on the scroll saw will slip through the hole you drilled.
Even better, depending on what result you are after and what materials you are working with, even if you cut through the letter, the kerf is so small that it will probably not be noticeable.
Experiment with both techniques and see which works for you.
del schisler
i do band saw box's and cut thro the outside to get to the little box part inside, what you do is a streight cut than whan you are done or have the inside cut out , you just put glue on the cut part and use a small clamp and clamp it togother, you will not notice the cut , just make sure that the wood is like even on the side and bottom of cut. that will work out very well
Most any scroll saw will do the job. However the better ones are so much easier and more pleasant to use. I stepped up to the Dewalt scroll saw after trying 2 Delta's. There was a world of difference.
Follow your local sales ads. I see scroll saws all the time for very reasonable prices. I bought my Dewalt for less than half the new price and it was hardly used.
