Vanity drawer tipping issue
Jess
I repainted a used vanity and have a problem with the drawers tipping down when I pull them out. I've included pics of one drawer bottom and the inside of where the drawer goes into. Is there a relatively easy solution to the problem?
Re: Vanity drawer tipping issue
Blocks at the top?
John in NM
Looks like that center runner just keeps the drawer going straight in and out. To keep it from tipping you might need to install some runners or blocks above the drawer for the tops of the drawer sides to bear against, preventing the tip.
Allan W
Allan W
Another option is to make a dovetail slide. Use a dovetail router bit to route the sides of the top slide and then make a new bottom piece that slides into the new groove. I know Rockler http://www.rockler.com has wood slides and guides. Many of the old dressers used the dovetail slides on their drawers. Just make sure you lube them with a light coat of wax.
