Way OT stuck rim
Way OT stuck rim
Way OT stuck rim
Dustmaker Mike
Alrighty a drive by gloat also. Yesterday I brought home a 660+ HP Shelby GT. the tires are pretty much racing slicks for summer use so I don't want to drive it in the snow here in Cleveland. A friend of mine has a 1998 F150 I am going to buy. The problem is it needs rear brakes and one rim will not come off. They are alloy rims and corroded on. We tried
Hitting them with a very big hammer
Loosing the lugs and driving it back and forth and round and round even bumping a curb
We have not tried heat hammer and cussing like a sailor yet that is going to be next.
Any other ways or ideas to get thing off with out cutting it off?
Re: Way OT stuck rim
Re: Way OT stuck rim - Kroil *LINK*
Bob Entwisle in NJ
Hi Mike,
Congrats on the GT!
As to the stuck rim on the 150, have you soaked the center hub with penetrating oil?
If you can get hold of some kroil and soak it that might help, otherwise the gas wrench is probably the way to go.
Seriously, Kroil is the only penetrating oil I've ever used that actually does what you applied it for. I've seen it work on horse-piss rusted fasteners on manure spreaders and such. Also used it to loosen fasteners on a salt water soaked electra-glide about 20 years ago.
Good luck, (you could just close yourself up in that new shop until spring and then drive the GT:))
Bob in NJ
http://www.kanolabs.com/
Scott Greaves
I had a stuck rim once. Of course we were stranded on the side of the road with a flat. We called the tire shop we use, and they came out with their mobile unit. The guy popped it off with a sledge hammer!
You might want to try spraying some penetrating oil in there to loosen things up, but using the big hammer is likely what will do it. Congratulations!
Scott.
Jason Roehl in Lafayette, IN
Use a jack.
Put a bottle jack between a part of the frame and the tire/rim (probably want to use a board against the tire/rim). Should pop it right off.
Jason
Kneale Brownson
My 1-ton had a stuck front wheel
Kneale Brownson
I got it loose finally by jacking it up with the lugbolts loose and dropping it quickly. Now I slather the hub/wheel contact spaces with antiseize on all my vehicles.
Galen Vetterick
The center of the alloy rims can really freeze on the back drums as you have found. Backing off the lug nuts so they are well clear of the taper seat. Then on a hard surface accelerate HARD and then brake Hard. It takes a good wheel twist from either to break the center loose. The dropping hard does not alway work as the force on the center does not help much to break it loose.
No pictures....?????????
Allan W
Allan W
We used to use a large sledge hammer and alternate between hitting on the top and then on the bottom. Make sure you soak with penetrating oil first. If the rim is alloy, the reaction between the metal and the alloy from salt creates a hard crust. If the rim is steel, a good soaking in penetrating oil and then working with hammer on the top and bottom to get it rocking should work.
