ADVERTISE HERE - FREE TRIAL
Changing my Unisaw back its orginial 3 hp motor?
Charles Jackson III
I am looking at rebuilding my 34-802 Unisaw that was built in 1989 so its about 23 years old. I am wondering how hard is it? I wont to replaceing the arbor bearings, strip off all the old paint and repaint the original color, also replace the Rockwell Unisaw 1-1/2 hp Motor that replace the 3 hp motor that I took out and get the Baldor new 3hp, Unisaw replacement motor,single phase, 230 v from Plaza Machinery since I am going to build a shop thats going to be wire. I ran the old motor off and extension cord, I hope I can sell the old motor for what I pay for it.
Re: Changing my Unisaw back its orginial 3 hp motor?
The first question - do you think you need to replace your arbor bearings? I'd leave them alone if they aren't bad.
Anyway - just pop the table top off and go for it. Disassembling and stripping the saw usually isn't a problem. Putting it back together and aligning it are the problem. Be careful and follow all the assembly and alignment instructions.
I had a friend who disassembled and stripped his Unisaw - he painted it with auto paint. I'd never seen a Unisaw with pinstripes and metallic paint before.
I think your biggest problem will be in getting the building electrical done.
Charles Jackson III
Yes it would, how you know arbor bearings need replaceing? The saw is 23 years old?
Stuart Hough
Charles, to check for bearing play just take your saw blade off the saw, and put a 3/4" box-end wrench on the arbor. Then install a fender washer on the threads and thread on the blade nut. Tighten the nut down, and then try to rock the wrench side too side and feel for any loosenes. If there is any, you need to replace the arbor bearings. Also, move the wrench back and forth like a blade and feel and listen for any gravelly noises that might indicate trash or loose ball bearings. That also signals a need for replacement. Hope this helps, as I have never tried it, but was told by a person that shops in my store.
mine screamed, "change me".
If there is not concrete evidence they need changing don't. Mine made alarming noises for months before I screwed up enough courage to change them. I have an Article in the Articles section on how to do it.
Now the motor. I have run a 1.5 HP motor for 30+ years on my saw and never saw any need for anything larger. If you visit the hand tools Forum you will see a massive 8/4 oak bench I just built and it involved plenty of 8/4 oak sawing. If I ran a production shop sawing 8/4 wood I would like a larger motor, but for a hobby shop I don't see the need.
Bearings...
John in NM
They make horrible noises. I just had to do the ones in my CSS, it's old too.
The other way you can tell is to take the belts off and see if the arbor rotates freely and doesn't go "thunk" when you grab it and try to wiggle it side to side or up and down.
Generally, if you don't know that the bearings are bad then they are good.
Re: Bearings...
Charles Jackson III
The Unisaw makes some kind of noise, once you turns it off. When I rip 8/4 stock with the 1-1/2 hp on a 100 ft exentsion cord it blogs down and blows a circuit.
Re: Bearings...
Bruce, a MN Galoot
Do you need a 100' cord? If you can get by with one, try a shorter one. If not, try a 12 ga. cord. Voltage drops with the length of the wire.
Re: Bearings...
Charles Jackson III
Well my 10x12 shed is not wire, the cord is 12 guage. And yes I need a 100'.
duh!
You can't run that saw off a 100' extension cord. The voltage drop will be huge on a 110 circuit. Switch the motor to 220 and run some wire to a box next to the saw.
Re: duh!
Charles Jackson III
I understand that now, thats why the new shop will be wired.
temporary plan
Switch that extension cord to be 220 V. The 100' run with 220V on a 1.5 horse motor will work fine. If the motor is typical it is trivial to switch it to 220V. The plate on the motor will show the wiring.
Don't know if this option is possible.......There is wire called direct burial. I ran 1000' of it in a shallow trench out to the road where I put a light and fence charger. You could consider temporarily rigging some 10 ga. version of this wire from source to shop. If your ground is not frozen it is quick to dig a trench with a nursery spade and get it down 6-8".
The problem with a motor is everything works against you. If the voltage is low the motor doesn't have full power. Then if it is loaded the RPM drops. The farther the RPM drops the more current it draws and that is when the breaker blows.
Re: temporary plan
Charles Jackson III
Ok thanks!
Re: temporary plan *LINK*
Robby Wright in San Marcos, CA
Bill - Your suggestion of 10 gauge wire is good. 12 gauge is too small for that long of a run. However, code requires underground cable to be buried at least 24 inches deep, if I remember correctly. You should also put a electical cable flag tape above it (about 12" deep) to warn diggers that the cable is there. Something like on the link below. They make tapes that are detectable by utility detectors too.
Underground Electrical Marker Tape
Re: article on bearing change
Hal
Hello Bill. Could you post where to find your article? Date and which sub-section should help. I know that sooner or later (likely sooner) I will have to replace the bearings on my ancient 3hp Griz (so ancient that it was made by Enlon just before Griz bought them out). TIA. Hal
Re: article on bearing change *LINK*
Bob Entwisle in NJ
Try here.
Bob in NJ
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=powertools&file=articles_724.shtml
Jesper, Denmark
Jesper, Denmark
Check article in the old Badger Pond section.
Hal
Thanks Bob. Brought up your link and there it was. Hal
Re: temporary plan
Jason Waters
A lot of people won't even just use direct burial anymore. Plastic conduit is so cheap these days. It might be cheaper to buy conduit and wire than direct burial these days.
Also, I remember digging a 24" + trench a few hundred feet through clay and rock when dad built a detached garage!!!
Maybe buy a 10 gauge extension cord. They do make them, though spendy. I bought one, and changed the plug ends to 220V for my garage until I could get it wired. I put one 220V receptacle right by the box, where the subpanel was going to feed from. then, when the sub was installed, I moved the receptacle and breaker (I had the same brand box) to the subpanel.
