REAL MILK PAINT
Delta 16 1/2" drill press - thread size on handle?
Paul Cates - Henderson, KY
I moved nearly a year ago and my ww shop is still in boxes in the garage. I'd like to use my drill press, but cannot find the handles and am wondering if I could temporarily use long bolts. Any idea if the thread on the handles is a standard bolt/thread size and if so, what size? 3/8" is too small...1/2" acts like it wants to start but is either too big/wrong thread or maybe metric. DP is about 13 yrs. old and says Delta International model 17-901. I have looked online and did not find any info in the parts diagram.
Re: Delta 16 1/2" drill press - thread size on handle?
John McGaw (Bodger)
On my Delta 16-1/2" (Model 17-900) DP the thread you noted is 12X1.75, or so my thread gauge claims. Mine was manufactured in 1996 and is one digit older than yours but I doubt that they changed that part drastically.
Thanks very much for the info! I'll get that size bolt and try it out.
Jason Waters
If you buy non hardened bolts, you can cut the heads off with a hacksaw easily. Then you can buy wooden balls (usually with a flat side too that is center dimpled) and drill blind holes in them and epoxy or poly glue them on the bolts. You might find they are nicer than the originals as you can use a different length or size ball, provided there is enough clearance.
I had to do this for a drill press once where a handle was lost and the plastic balls all cracked.
Excellent idea! Thanks.
George Colonel's Workshop-Havertown PA
good afternoon Paul,
That is exactly how I handled the problem. I wound up with a comfortable set of handles, sligbhtly largerthan the originals. The replacement balls are birch.
George
Sounds like you handled the problem well
Definitely a man with well-rounded skills, Col.
And had a ball
