ADVERTISE HERE - FREE TRIAL
OT-paint/gunk remover???
Tom Dunlap
For many years chainsaw users have been using veggie oil, typically canola, as chain/bar lube. Now, what we're finding is that this stuff mixes with the dirt and chips and then cooks itself into a rubbery, nasty gunk inside the saw. Using compressed air on the outside and easy-access places routinely keeps the saws 'clean'.
At my new job I've inherited a fleet of saws that haven't been kept very clean. The gunk has covered the chain brake mechanism so that it doesn't work. That means a tear-down and cleaning.
I've been trying to find some soap/solvent that cleans the oil gunk off like the petro solvents do on saws using normal bar oil. Air, some mineral spirits and a little scrubbing will clean a non-veggie saw. Carb/brake cleaner gets into the tiny holes and leaves the saws clean.
Besides just plain picking and scraping the only help that I've found is to soak the removable parts in a heavy concentration of Krud Kleaner followed by hot water scrubbing. There still is gunk in the nooks and crannies.
Mineral spirits after some preliminary picking/scrubbing seems to work too. This seems to be what I'm going to be using now. The catch is that spirits is too thin to 'sit' on the parts that are the hardest to clean. Over the past couple of days I've been trying to figure out a way to make a jelly out of mineral spirits. That leads me to thinking of some sort of paint stripper.
I seem to remember that adding soap flakes to gasoline makes it into a jelly. I wonder if that would work with mineral spirits to keep it in place.
Any other suggestions would sure be welcome too!
Tom
Re: OT-paint/gunk remover???
C. John Hebert
I use either gas, or carburater cleaner with spray tube
Tom Dunlap
Are you using veggie oil for bar/chain lube?
Those solvents all work well for petro oil but not on the cooked-on veggie gunk that I'm finding.
Tom
Why there is the problem and a cheap alternative
We would all know not to use linseed oil in this application because it would cure to an intractable film. Well, most of the vegie oils enable the same chemistry to occur, just to a lesser extent so that the film is not as hard, but rather gummy. Olive oil would be a better choice as it lacks the chemistry to enable it to "cure" to even a gummy film.
Oven cleaner will work dandy to remove the cured oil. Paint stripper will too.
But why!?! Personally, I use the filtered stuff that drains from my car's oil pan for this application. Costs nothing and works fine. I have never had a bar wear out in 40years of sawing firewood or occasional timber cutting. Alternatively the cheapest motor oil that can be bought is next best for the frugally minded. But really, the synthetic oil from the oil pan is better.
Re: Why there is the problem and a cheap alternati
Tom Dunlap
Bill,
My conversion to using veggie oil happened after spending a few hours blocking logs into firewood lengths. Two of us used over a gallon of petro oil in our saws. When I was done I realized that I was doing the work a hundred yards up hill from a wetland. Hmmm...where did most of that gallon of oil go? Yup...onto the ground and into the wetland. Sure, some will be eaten by microbes but not much.
The other reason for using veggie oil, especially for professional chainsaw users, is that the oil atomizes/volitizes and is breathed in while cutting. It sure makes sense to use something less toxic than petro oil. Maybe olive oil is a better solution.
For a while I used old engine oil. It was economical and the bars and chains didn't wear out any faster. I stopped using it because of the stink. Blechhh... Again, much different when I might use 5 or 6 different size saws in a day and a homeowner might use a saw a time or two a month.
I'm OK with the company, and personal, policy of trying to be a little more environmentally sensitive. Even if this costs a little more in maintenance, its worth it.
I've tried oven cleaner too. It would soften the gunk but not loosen it's grip from the saw. The list of petro solvents that I've tried is the usual stuff...nothing seems to loosen the grip except mineral spirits.
Tom
Tom, since it is in effect a "painted" surface - since the Vegetable oil has cured just like tung or linseed oil, why not use paint remover. If your concerned with the environmental issues I'm sure some are more environmental friendly.
steam
Bruce, a MN Galoot
I worked in an industrial-sized food plant for half a year (we made 750,000 lbs of french fries each day). The plant had just that kind of stuff in some places, and we used a 30-lb steam line to clean them. It works really well.
Re: steam
Tom Dunlap
Oooo...great idea! Now the search begins to find a small steam unit!
Tom
Ya know,
Bruce, a MN Galoot
The engine rebuilding place where I get some machine work done has a pressure steam cleaner to really clean/degrease engines before they get torn apart. They must have one of those in NC.
More information
This project perked my curiosity. So I looked on the Bailey web site for biodegradable bar oil and sure enough the description of the biodegradable bar oil from Motion Lotion answered a lot of questions.
I suppose you are using Canola (Rapeseed) oil because Motion Lotion says their stuff is derived from Canola oil. Indeed, of the common oils as they are refined for food use only Olive oil might gum up less. I would not guarantee the difference would be dramatic (but it might).
I am speculating that the Motion Lotion statement "derived from Canola oil" may mean that the Canola is partially hydrogenated and it has a truck load of antioxidants added to reduce this gumming-up tendency. It would be interesting to know if the Motion Lotion oil gums up less. If so, there is the reason why.
Also Motion Lotion repeats the questionable claim of less operator exposure to "toxic" petroleum oil. I expect oil rig operators would find this concern entertaining. Petroleum bar oil is not going to be significantly volatile at temperature of use. If I was going to fret about this kind of issue I would be worrying about the exhaust from more or less burning the 2-cycle oil.
My suggestion of using oven cleaner is NOT to be employed. The kind that will readily remove the partially solidified vegie oil (contains sodium hydroxide) will also attack the aluminum used in this part of the saw.
My daughter is working on a synthetic lubricant project that would solve this gumming and biodegradability issue handily. I will ask her if they are aware of this bar oil market. Maybe she can send you a quart to try.
Re: More information
Tom Dunlap
Hi Bill,
Motion Lotion and other commercial veggie oils are a bit different than food grade oils. No one will tell us what the differences are though. There are vague claims that sound more like 'carny' talk than any real differences.
I've asked this same question on arborist and chainsaw users forums for a while now. No one has a solution for the gunkification but everyone, even the users of commercial veggie lube, have the problem.
You're right, the concern about exposure may be exaggerated. Exhaust is MUCH more toxic of course. We operate the saws within arm's reach and the exhaust is pointing directly towards our faces many times too. Not good! I try to hold my breath when making short cuts though.
I'd sure give any solution a test. If your daughter's solvent works there would be a good market, even if it is small.
Tom
