enlarging
enlarging
enlarging
papa
I have a 3in. letter " M" I need to blow it up to 24in. any ideas on how to do this .
Re: enlarging
Pantograph
Merle
This particular pantograph will enlarge up to 10 times the original dimensions. HTH
http://www.leevalley.com/US/wood/page.aspx?p=32535&cat=1,42936,50298
Re: enlarging
Re: Pantograph
papa
Thanks Merle just about to order one
Re: enlarging
copier
You may need a trip to Kinko or Office supply to get this big but I expand or shrink stuff on a copier.
Re: enlarging
Do it in pieces
You can enlarge it larger than your copier will print. Just move the small one around on the glass and enlarge it the percentage you need. Then cut out the pieces and tape them together.
Re: enlarging
Re: Do it in pieces
Don in Central Illinois
Make a copy with transparency (paper) and use overhead projector. Our churc did that when they decorating the chikdrens area. Took small itens, projected on the wall, traced it and painted. 'Course, you have to have access to an overhead projector.
Re: enlarging
"Overhead" . . .
steve mackay
Whenever I need to do such a thing I always seem to know someone with an overhead projector. Church, school, office. I sneak in, do it to it and sneak back out.
Re: enlarging
Other responses are correct
Gary Smyth
and you could also do the photo slide to projector route. But if you don't have the tools or the time the easiest method would be to hit a local fast sign place and have them make it to the scale you want. They can expand your original in a vinyl that will be the same as the scanned "M" or they can cut a stencil where you carefully peel the letter out of the background. With a large amount of vinyl this can get expensive, but if you need accurate proportions and perfectly straight (or curved) lines, it may be the better solution. If you do this get info and practise before releasing the backing. Once down it can be pulled up, but the vinyl will stretch and destroy the smoothness you spent the money to get. For first timer it is tricky.
Re: enlarging
Re: enlarging
papa
Thanks everybody but I have to go with the pantograph cause as soon as grand daughter #2 see's it it'll be I want one then
grandson #1 so it's and on and on it'll be cheaper with the pantograph. again thanks
Re: enlarging
Magnajector
Tom Dunlap
Grandma bought my sis and I a Magnajector for Christmas one year.
I've used it several times over the years. It's worth looking for, Ebay must have a few for sale.
Tom
Re: enlarging
That brings back memories from 50+ years ago
