Learned something new tonight
Dale Lenz
Was rubbing some lacquer finish with Scotch-Bright material (green, maroon & gray, in that order) on non grained filled black walnut, and expected and did get the white swarf in the walnut pours. My plan was to shoot another light coat of lacquer on the walnut and call it good, as lacquer or shellac will dissolve the white swarf. Before getting that far, I blew the walnut pieces off with compressed air, about an inch from the air nozzle and blew out all the white swarf. This is knowledge I had not noticed/heard of before and I've heard of others with the same complaint. Would think wet sanding might not result with the same results, as the moisture would "cement" in the lacquer swarf.
