How often do y'all replace pads and brakes on ROS?
I took off the pad for my 5" ROS. The brake and the metal facing on the pad are pretty much shot.
Obviously, I need to replace them. So I ordered a brake and a new pad.
That got me to wondering - it's been several years since I bought this ROS and I've used it heavily - but I've never really thought about replacing a pad or brake. My last ROS just stopped working so I got this one (PC 390K). I admit I do a lot more woodworking nowadays.
Re: How often do y'all replace pads and brakes on ROS?
I have two of the PC 5" ROS. I replace the pads about once a year or more and have completely rebuilt one of them. I am a little disappointed in them and think the H&L pads should last longer. Home depot carries them for about $13 and I usually have a spare on hand. I really like the sanders, but I still think the pads are short lived.
On a side note, I bought some Diablo (sp?) disks for them at Home Depot. Fairly large packages, about 20 or 25 disks in each for about $25 each package. They were nearly worthless. Would not stay stuck to the pad. Even tried a brand new pad. Took them back to HD and the young assistant manager type woman blew me off. I left peacefully but thought to myself.."wrong answer". Sent an E-mail to the big HD in the sky and to whoever makes Diablo. (Freud?) HD central called and offered a $25 gift certificate. I said thank you, but the sand paper was about $50, so they upped the offer to $50. Thank you very much. Sent it too me in an E-mail. I took the sand paper back to HD and they insisted I was not required to return them. I insisted they were worthless to me and they needed to return them to Diablo.
I bought a few packs of Diablo 6" PSA disks for a bench mounted disk sander and had the same problem. They would not stay stuck to the disk. Regardless of how well or what I cleaned the disk with.
Bob
I replaced my sander pad once. It was hook and loop and after I talked to a small local sandpaper provider I went with a pad made for adhesive. I have never had to replace it, but then it doesn't really get a lot of use any more. I have never replaced brakes on my sander, but it's a Dynabrade. My DeWalt electric orbital gets very little use.
I've only replaced my pad once, just this fall after years of service. Bosch vs5", went ahead and replaced brake ring at the same time. my h&k was fine but the backing foam fell apart. I would note to others using diablo or "other" box store paper to try Klingspor's paper, it's super and way cheaper.
