Curved edge for a stage.. ??
Ordinarily when I make a curve for a piece of furniture - I either steam bend it, glue laminate it or make it "brickwork" style.
I want to make end caps for the edge of the stage.
They will be covering the stairs for the most part.
I figure I'm going to trace the original curve on a piece of plywood and use that for the top. I was going to follow that edge (after sanding).
I was figuring on using 2 x 4 or probably 2 x 6 for the outer edge. I can use my band saw if I do it by brickwork. I could also resaw a 2 x 6 or two and do a glue lamination. I could also sacrifice some of my air-dried lumber and steam bend it - but I'd rather not chance that.
How would y'all do it?
Re: Curved edge for a stage.. ??
I've seen discussions of Trex 1x6s that point out that one of their weaknesses - flexibility that requires more closely spaced joists - is a benefit when doing curved skirts. That seems like one possibility.
I think I'd frame it in a very, very rough approximation of the curve, install blocking on 16" or thereabouts centers that mimicked my desired curve, and then use 1x stock of some kind (see previous paragraph, but even pine will bend this much, I think) screwed to these blocks/framing, with the screw holes plugged.
Does this theater group let you hold down a paying job and eat and sleep? Seems like they keep you jumping!
Job? What's that?? I stopped working for money about five 1/2 years ago.
Lee Schierer McKean, PA
A couple of assumptions:
1. This is to be a temporary change to the stage.
2. Cost is to be considered.
For ease of framing, Frame up the curved side as a straight or series of angled pieces and make it just 3/4" short of the final dimension on the front edge where it meets the existing curved front. Build your frame adequate to support the expected loads, Then get a piece of 1 x ? that is long enough to span the exposed front edge from end to end and that is as tall as the needed trim. Anchor the end next to the existing curved edge to your new frame. Then just bend the 1 x ? to the needed curve outside of the frame. Bow it out in the middle with shims to get the desired curve. Once the needed curvature is reached trim to length and nail it securely in place. Your deck boards can help hold up the curved edge piece. The curved edge does not have to support any weight other than itself.
Lee
Thanks - should work
I'll see how limber the 1 x 6 is at H.H.
If needed you can back-kerf it
I did a 1x4 baseboard around a much tighter radius than that in a high traffic area in the kitchen, by kerfing the wood every inch or so, leaving if I recall correctly 1/4" of wood - that is, the kerfs were 1/2" deep, all cut with a circular saw. It held up to two boys, a very large dog, and multiple cats for well over 25 years before we remodeled the kitchen.
