re-doing my shop
I bought a cabinet saw to replace my contractors saw. I had to completely rearrange the shop to get it in. I'm now building the saw inserts because it only came with one with a very wide throat. I'm also adding a lift up table to the back side of the saw so can saw larger panels by myself. I had to leave the shop for a while due to the contact cement fumes.
I move the bandsaw to the left of my carving bench. I hope that was a good choice. It seems like it might work except for ripping boards over 6 feet long but I rarely do that. I am going to add a larger table to it and see if I can figure out some way to improve it's dust collection.
The thickness sander, planer and jointer will have to be moved to use them but they are all on rollers. The jointer will actually work where it is but will have to be moved to empty the dust collector so the wheels are a good idea. I used the flat refrigerator mover wheels. They work well. I just put a wedge under them when I'm using the machine. I may move the drill press over to the right of the metal lathe since that's where I store all my bits anyway. I'll move the scroll saw over where the drill press was.
I have a lathe hidden in this photo. It's stored behind the big brown cabinet for now and is in the way. I can't move it back until I sell the other table saw and get it out of the shop. So for now the red cabinet and stool with my sanding supplies are just out in the way as well.
