lining my drawers
lining my drawers
lining my drawers
james jacomb
I'm using some PSA velvet to line my box drawers. Never used this stuff before, wondering if finishing first with poly would affect adhesion. And yes I know flocking would be a good alternative if I had the time and money :) Thanks
Re: lining my drawers
David Barnett
(Message Deleted by Poster)
Sources?
Henry (Raleigh, NC)
So David - if one were to want to follow your advice and use natural velvet, how does one tell? Are they labelled as such (natural or synthetic?). What are good sources for natural velvet?
Henry
David Barnett
finish
If you ever need to replace this stuff the PSA may release from the varnish but it will be forever stuck in the pores of the wood.
Re: For comfort?
james jacomb
I have used regular velvet before, little tricky to work with if you are not using a liner like you suggest. Some of my work is compound curves, like lining an egg shell. I'll use what I have for now and search for a different method to adhere regular fabric.
By the way, the image is a #2 shaker box, abalone veneer on top, the underside is lacewood with a srimshawed inlay of pink freshwater clamshell, the image is a redheaded mermaid!
David Barnett
Re: A suggestion
james jacomb
Yes, the lam is from luthier suppler.I've used some to inlay images into / onto handles of custom fishing nets. Fun stuff, similar to instrument inlay.Thanks for the helpful suggestions. I really like the idea of checking out some used fabric sources... upcycled!
David Barnett
