Working to scale - Cornel Schneider *LINK*
Re: Working to scale - Cornel Schneider *LINK*
Keith Newton
Thanks for that link David. That guy's work is incredible. I've been getting some great macro nature shots over the last few years, of subject matter much like those, and even though I started carving little things like that back in the sixties, I had not even thought about getting back in that mode, but I noticed everything in his gallery is sold.
By the way, my thumb/stump is all covered with skin now, but very tender. For some reason, as it was healing, it looked a lot like there were annual rings, like trees grow. ha,,,,,,,,
Incredible *LINK*
I can't imagine having that kind of patience, or tools, or materials, or workholding fixtures -- or any of it. And, carving in boxwood must be a challenge, too.
My departed friend Dayl Gable worked in a similar vein. I've archived some of his works here on WoodCentral, and I have hundreds of slides of his work yet to scan. Someday. Maybe.
Thanks for posting this. Work of this caliber is rare.
Gable Gallery
Keith Newton
David, I mentioned having lots of Nature macros that I have taken in my earlier post in this thread. After returning to your link, it dawned on me that I should have shared a few sample shots.
Here is a link to a few or several thousand that I have taken, and yet to find a way to utilize. Thought you might enjoy seeing some of my other talent.
http://www.flickr.com/photos/7391658@N03/8288053986/in/set-72157632282467543/
Terrific photos..
Gary Smyth
but Flickr for me is difficult to navigate and I did not find captions, other than a date, to fufill curiosity about what you used as to camera, lens, and illumination. The depth of field is great in the examples. Were they set ups or field? Electronically manipulated? Nice work.
Re: Terrific photos..
Bruce, a MN Galoot
I don't know what happened to the exif data, either. Flickr changed this just within the last few months - it used to be available unless specifically blocked. Now, it just seems to be missing.
Thanks Gary,
Keith Newton
Those are all in the wild shots, taken with a Canon SX 20, either in macro, or super macro, or with a Raynox 150, which cost about $50, and will clip onto most lens.
As for lighting, all were taken with on-camera flash, with a simple DIY diffuser, which is simply a length of welding wire, although a coat-hanger will work, bent into a loop around a piece of pipe 360º, then out and up like a couple of insect antennae, sprayed with contact, laid on white plastic grocery bag. It is quick and simple to make, and works great for macro, in that I have full control of through the lens metering.
I usually shoot -1/3 stop, and -2/3 on the flash. This keeps from blowing out any of the bright areas in the frame, then the only manipulation after I get it into the computer, would be usually a little minus on the contrast, then maybe a bump up on saturation if the first washes out the color, then nudge up the exposure or brightness.
But probably the main thing, is being in rich environment at the right time, and being tuned into nature, and curious about everything within eyesight or hearing range, and knowing how to approach the subject, and building on what I learn each outing, dispelling fear, focus on the moment, and learn any and everything about each and every subject which I capturer. But most of all, nothing beats just dumb luck, which I happen to be the one of the luckiest around. But then, I do work my ass of at it, when I'm in the zone..
As for the missing data, about a year ago, my computer crashed. I had a back-up, but all my titles, and other interesting stuff about finding and the situation was lost from those images. Since getting that into this computer, I'm afraid going through 10,000 images, and trying to restore what was lost, has just been too daunting. I think I had enough compiled for a decent book, "Fieldnotes from Frogwarts", if I could have gotten some help with organizing it.
Exif data on Flickr
Bruce, a MN Galoot
Found it!
On the menu bar above the pic, choose "Actions" and then click on "View Exif data"
