I am making a plant shelf. Plywood substrate, tile, wood mitered trim around it and it sets on a frame with legs. I don't have any Thinset on hand. I have lots of tubes of construction cement. Can I use this cement to stick the tile to plywood?
You might call the manufacturer. The local tile wholesaler tells me that you should use a mastic rather than thinset to stick tile to furniture - construction adhesive, if by that you mean the stuff that comes in tubes, is kind of mastic-like, but I don't know to what materials it will bond.
Thinset would be appropriate for attaching tile to a water-resistant backing in a wet environment. While a plant stand might fit that requirement it doesn't seem likely unless you are planning on massive overwatering. I have successfully used mastic to stick up tile backsplashes on drywall and have used the material sold in tubes as 'paintable caulk and sealant' on the backs of tile to stick them to wood for coasters and trivets with good success (in other words, no failures that I've seen).
If your shelf is going to become wet repeatedly from plant watering, I'd use some kind of tile backer between the plywood and the tile. I'd also use a tile cement and grout.
If it's going to stay dry, a mastic would work. I've also use silicone sealant to secure tiles.
It's usually sold pre-mixed in the tile aisle at Home Depot or Lowe's. I think it's for tile jobs where there's no chance of water getting to it. You could probably safely use it on a kitchen backsplash but not if you were tiling a countertop.
Bill, I used the mastic when I set 350 tiles on my home floors in bath, laundry, hallway, kitchen and side door entrance. It comes in one gallon containers and is the consistancy of peanut butter....goes on real nice with a knotched trowel. Then grout with a good non-sand grout and you should be good for the planr shelf. But, seal everything with a sealer before using the shelf.
This is how I approached a similar project. Set tile with a shmear of PL Polyurethane construction adhesive; sanded grout after a coat of finish on the frame.
Bill, I have used PL 400 Construction adhesive many times to glue slate to plywood floors and to the steps in my house. The steps are 2X10's. It worked perfectly and has held up to for over thirty years. I am not an expert, but I am sure a Liquid Nails type Product would work well. (I laid it out and then lifted each piece and put a little circle of stick-um down with a caulking gun and pressed the piece back into place. The glue is initially slippery and you can slide the pieces easily. Too easily. You should have spacers on hand to keep your grout lines constant.)
One home owner decided to tear out the slate in his foyer after about ten years. He tried everything he could think of including pouring lacquer thinner on it to the point he was afraid his house might explode. Tried beating on it and getting under it with a chisel. Finally tore out the plywood and all. Left it sitting in the woods behind his house until the it rotted.
