Need assistance designing a "desk"
AZ in Colorado Springs
A friend has asked if I can build him a desk that can be configured either as a "normal" desk (actually more like a small table) for use while seated, and can be converted to a standing desk.
This piece of furniture would have no drawers, and can have no apron or stretchers across the back, as the back is desired to be open when used as a standing desk (in this description, the "back" is the side where the user is seated or standing, and the front would be the side where others approach from).
The length and width would be 36"x24", and the height either 29" or 43".
I've seen no plans available for such a desk.
I'm thinking frame and panel construction for the sides and front, probably dovetailed where the front and sides meet, along with some angular braces to provide rigidity. The top (itself probably a fame and panel assembly) would rest on the top edges of the sides and front, registered using dowels or larger tenons. To elevate the top 14", three separate panels would be positioned between the base and the top along the front and both sides, the top laid down again, registered in the same way with dowels or tenons.
But how to ensure the whole structure is sturdy enough for for regular use and survives several moves in a military career? Suggestions?
Thanks
Andy
