CNC Machine
CNC Machine
CNC Machine
Tom Rex in TX
For those of you that have a cnc routing machine i would like to know
1) Which one do you have
2) Are you satisfied with it
A) If not, what does it do not do for you
3) If you had the chance to replace it which one would you purchase
4) Which programs does it support
5) Are they easy to use
Thanks for taking the time to answer,
T Rex
Re: CNC Machine
Tom, Here is a link to another forum *LINK*
Keith Newton
I'm not sure many on this forum are working in that mode.
http://www.woodweb.com/cgi-bin/forums/cnc.pl
Re: CNC Machine
Re: Tom, Here is a link to another forum
Tom Rex in TX
I'm afraid I don't belong over there because it looks like it's for professionals.
I posted my questions so we'll see what comes of it.
Thanks for your response.
Re: CNC Machine
You can also try
John in NM
CNCzone.com and routerforums.com, both have forums dedicated to cnc routers and are a bit more friendly than woodweb.
Not a lot of cnc guys seem to hang around here. I had looked into it a little recently for some true 3d work. I found the prospect of getting a useable 3d model absolutely daunting, but then I'm also hampered by a preference for open source software :D
Re: CNC Machine
Re: CNC Machine
Dick Coers
Tom, CNCZone is the place to go. I run a 5 axis MotionMaster in the model shop for a day job. About $200,000 and $35,000 software. That's a guess since it is 12 years old now. You better tell us what you want to make, or do. Bench-top or 4'x8 min'? You will need two pieces of software. A CAD, and a CAM. The CAD does the drafting of lines and arcs (and surfaces if you want to do 3D) and a CAM software to write GCode to control the CNC. You are working with a robot, so every movement of the 3 axis takes a line of code to make each stepper or servo motor turn. Sometimes, 3 motors at a time. It's not easy at the start since you have to learn both softwares. It can take 6 months to really get confident. Support from the companies is the most valuable asset you can buy. Mine was down recently since I got a warning code that was not in the manual. Took a couple hours on the second morning to find out how to resolve it. So a great community (forum) can be a great asset. You wouldn't believe how rigid these things need to be. Electric motors go from 0 to fast instantly. You have at least 3 motors controlling the motion, so it really snaps the machine around if it is light weight. I've seen 1/2" thread rod on little machines whip around like it was made of rubber. Give us some direction you are thinking about, then we can help.
Re: CNC Machine
Re: CNC Machine
Tom Rex in TX
I'm looking for something like the Mako Shark or or the Shark Pro Plus sold at Rockler.
Price under $4,000
Table about 30" X 30"
Z axis about 6-7"
Re: CNC Machine
Re: CNC Machine *LINK*
Dick Coers
Here's a link to a nice article on diy starter machines. You will read on cnczone that a lot of guys build their own in this price range. To me, the starter routers are way overpriced for what you get. I would make my own in this range, and probably a JoesCNC.
buyers guide
