Finishing problem
Warren White
My friend (a real craftsman) has built a couple of new cabinets for his front room. He made the cabinets out of material he salvaged from cabinets he made before and from new materials.
We sprayed the cabinets with flat black as a primer and then with semi gloss black as the finish coat. So far the parts (door fronts and trim) made from MDF look good; the parts he salvaged from pre-finished plywood also look like glass. The problem is the parts made from new wood (most evident on the sides which are made from unfinished plywood) look awful. The grain of the plywood is showing through. All parts were thoroughly sanded.
In hind sight, I think we should have used shellac as a sealer for the wood and then sprayed it.
The questions are: 1) Will additional coats of the semi gloss finally cover the grain? 2) If not, what do we do?
Thank you so much. The folks on this forum are great!
Warren
Your best bet is MDO, a paint grade, pre-primed waterproof ply used by sign painters, but that is hard to find and expensive, and anyway it's too late for that now.
