ot adjusting headlights
Jerry Gibbs
I want to adjust the headlights on my van. Any guidelines for making sure the low beams are effective without being too high so that they interfere with other drivers? Jerry
Re: ot adjusting headlights
van is 2000 Econoline
Jerry Gibbs
Lamps have 3 bumps on the front. There appears to be one adjusting screw on top and one on the side of each lamp.
Re: van is 2000 Econoline
John McGaw (Bodger)
There are any number of how-to guides on the web. Do a Google search for 'aiming headlights'. Often, the most difficult thing is finding a dark enough location and a suitably-large target at the proper distance. I used to use a white warehouse building with an adjacent parking lot. Your van's service manual will have the proper parameters and your state's motor-vehicle code may have things to say about aiming too.
There's up and down and side to side, too. As John says, see what you find on the web. You may need to find a white building side on which you can draw lines, whether with a sharpie or with painter's tape.
You mention that it's an Econoline; if you normally carry heavy loads in it (as tradesworkers will often do), you should adjust the headlights with the normal load in the back. A van full of passengers won't usually sag enough to affect the aim, but sacks of concrete, if there are enough, sure will.
Then dig around to find out how to adjust them. Your library may have a Chilton or Motor's book that will explain. The traditional adjustment involved screws on the sides of a headlight "bucket" (which carried the headlight); these would require either a long, thin screwdriver or the removal of the trim around the headlight. Newer vehicles often have little thumbscrews on the back side of the headlight bucket.
Joseph Mulherin, sr
Jerry, from an oldtimer....put some painters tape on your garage door at the height of the headlights
on the Van; place the Van about 20ft away from the door; the painters tape is in a cross at the the place where you want to start aiming the lights with the screws; for the low beams you want them to shine in the lower right side of the cross and when the lights are clicked onto bright the glow should be in the upper righthand side.
Don't ;et the lights shine in the left side because it would be hindering the oncoming drivers.
Thats the way I have always done mine.
this what I needed- thanks
