Re: Jet Drum Sander Failed Mother Board Control
Alan in Little Washington (NC)
Are you sure you don't have a jet 22/44? Here is the info straight from a Jet 22/44 Pro document:
"The conveyor belt is driven by a separate 1/30 HP DC motor."
A write-up on NewWoodworker dot com about the 22/44OSC says: "The conveyor belt is powered by separate 43 inch-lb DC motor. This DC motor was selected in part to support variable speed and a special bit of protective technology described in the conveyor section below."
"Using the DC motor to power the JET 22-44OSC Oscillating Drum Sander conveyor belt clears the way for variable speed. However, JET also developed their patented SandSmart™ technology that works with the variable speed control. The infinitely variable speed control produces feed rates from 0 to 10 feet per minute. That lets the operator choose the best rate for the job at hand.
The SandSmart™ technology monitors the load on the conveyor belt. When that load exceeds its built-in limits, the SandSmart™ circuitry automatically reduces the feed rate to a slower rate as long as is needed. When the load is relieved, the original feed rate is restored. An LED light next to the speed control dial comes on when the SandSmart™ system has taken over."
From the Jet 16/32 manual: "Conveyor Motor: 43in/lb. torque, direct drive D.C. motor, infinitely variable rate of 0-10'/minute."
I think you can safely assume your "mother board" is a DC controller (which means is has an inverter inside) and the motor is a DC gear motor.
I have seen a lot of reports about failed conveyor motors. Found this comment from 2009:
"PS, I ended up needing another speed control too, since it cooked as soon as I turned it on and I finally found one at KB controls.com, Pt# KBVC-14. Surprisingly reasonable."
