Help with oversize pin hole
Robert Tutsky
I have a Skil 4 x 36 inch belt sander. Now and then I use the 6" side circular sander disk. Problem is with the adjustable table that is attached to the machine. It adjusts from level to 45 degrees for guiding stock through the sander. The pin that rotates in the hole for adjustment is incredibly sloppy. It isn't worn but was manufactured with too large of a hole from the beginning. No matter how tight I try to get the knob to lock the table it moves at least 5 degrees off level when sanding. My thought was to fill the hole with JB Steel Reinforced Epoxy then re-drill the hole to the correct size diameter. Question is, do you think this would work long term or do you have a better idea? Thanks in advance for your help.
