bolt nomenclature
Jerry Gibbs
I need a bolt that is designated "Hex Head Bolt M8x20 L.H". What does this mean?
bolt nomenclature
Jerry Gibbs
It means
Bruce, a MN Galoot
Go to your hardware store and ask for their left-handed thread metric bolt section, and you will find it there. 8mm thick and 20mm long
Re: It means
Robert Hayward
Good luck finding that in a hardware store, at least around here. Metric alone is not all that common in a hardware store in this area. Let alone a left hand thread.
Bob
any kind of thread from my info?
Re: bolt nomenclature *LINK*
Andy Lincoln,in Dearborn MI
Jerry,
Might this be the part you are looking for?
I am not sure of the pitch of the threads but I would guess
being a left handed thread there are not as many options .
Andy
http://www.ereplacementparts.com/hex-flange-head-bolt-m8x20-p-487.html
Try an auto parts store.
Jerry Gibbs
looks like it would work- Jerry
Re: It means
Bruce, a MN Galoot
My Ace hardware store has a whole section of metrics, both LH and RH, cap screws and hex. This is farming country. They have to.
More likely a tractor or motorcycle shop.
not enough info.....
Dick Coers
There are two thread pitches for 8mm bolts. 8x1.25 is standard thread, 8x1.00 is the fine thread.
You should be aware that there are two common metric thread pitches in 8mm bolts - 1mm and 1.25mm. This designates how many millimeters per thread (it's the inverse of the inch-fractional approach, which designates how many threads per inch). If you don't know which pitch your bolt needs to be, get both; you'll be able to tell right away as you thread it in whether it's right or not.
Ralph Lipeles
Since you seem to be missing the pitch (threads per inch) try hunting around on the piece that needs the bolt and see if you can find one that appears similar to the one you are looking for. Bring it with you when you go shopping.
Ralph Lipeles
Bob Entwisle in NJ
"A metric ISO screw thread is designated by the letter M followed by the value of the nominal diameter D (Dmaj in the diagram above) and the pitch P, both expressed in millimetres and separated by the multiplication sign, × (e.g., M8×1.25). If the pitch is the normally used "coarse" pitch listed in ISO 261 or ISO 262, it can be omitted (e.g., M8)."
link to the full text of the above quote attached.
Hope this helps
Bob in NJ
http://en.wikipedia.org/wiki/ISO_metric_screw_thread
get it here in stock
del schisler
the link http://www.toolpartsdirect.com/cgi-bin/parttools.cgi/314348
Hitachi BOLT M8x20 LEFT HAND
Part Number: 314348
$3.25
it probly is available at a tractor supply or ace hardware ?
