Any Way To Renew Push Pad Stickiness?
Derek Arita
I've got a bunch of push pads that I've collected. They originally came with machines. I've noticed that they've lost their original stickiness. Is there any way to renew the surface stick?
Re: Any Way To Renew Push Pad Stickiness?
soap and water, let dry
Bob
Bob
I found a great push pad I use a rubber trowel that is used for grouting tile. It has a softer rubber under the white layer so you just use the band saw to slice it off. OR I also have use a self stick rubber backed 4" wide sold in a roll for non skid surfaces on outdoor stair treads that I cut to length and stick to the pad.
I don't know, BUT
Bruce, a MN Galoot
I made a couple good push pads using old mouse pads. Cost = 0.
