Anyone Use T5 Lights?
Derek Arita
I have to add a light fixture in my garage and want the max light I can get, with low power use. I've been reading about T5 and it sounds pretty good. Can anyone recommend these? I'll be using 48" x 4 fixture.
Re: Anyone Use T5 Lights?
I do.
Bill Tindall
I recently posted on this topic. Do a search as it was about a month ago.
The amount of energy a lamp uses is nearly insignificant compared to other uses so personally I don't pay any attention to lumens per watt. I look for lumens period.
The T5 HO fixtures put out 5000 lumens per lamp, or a boggling 20,000 for a 4' 4-lamp fixture. These are 54 watt lamps. I replaced 12- T12 and T8 lamps with 8 T5HO and increased my illumination 50% to 300 ft candles in bench area.
T12 puts out up to 3200 lumens for a 40 watt 4' lamp, or substantially less for other lamp choices. I think it makes no economic sense to replace T12 with T5 in a residential situation if the lights are on a typical residential amount of time. However, as of 2013 40 watt T12's will no longer be made according to my local lighting supply store. So stock up or switch.
Woodie49
A friend put them in his shop, boy what a difference from the old ones!
I will be putting them in mine!
Derek Arita
Here's the fixture I'm looking at...
http://www.amazon.com/Commercial-Tube-Fixture-Light-Size/dp/B002TJOGLE/ref=sr_1_1?s=hi&ie=UTF8&qid=1354412144&sr=1-1&keywords=t5+light+fixture
will these be hi output? Will I be able to hard wire them with my other fixture? My other fixture is an old kitchen unit that I plan on using T5 retrofit units in.
Woodie49
Should work.
