Plumbing Problem
Dave Bair
When I push the plunger down in the bath sink, the plug lifts but the sink drains very slowly. If I "burp" the plug by tiling it sideways, a few large bubbles are expelled and the sink drains quickly. What's the deal?
Plumbing Problem
Dave Bair
Re: Plumbing Problem
John McGaw (Bodger)
With a malfunctioning drain in a vanity sink my first thought is a hairy clog. In this case, possibly a big wad of gunk hung up on the plug operator lever would be my guess. It never hurts to pull the trap and the plug and clean things out (well, it never hurts as long as you don't break anything and can put everything back together again).
Joseph Mulherin, sr
You don't have to pull the entire trap out to clear the clog. John is correct in the you have some hair built-up on the drain plunger lift rod. All you have to do is unscrew it from the back of the drain tubing, clean it off, let the drain in the sink stay in place and fill the sink totally, then lift the drain plug and let the water wash everything out in a good gushing of warm water.....works fine for me a couple times a month.
hairy clog
Dave Bair
The first thing I did was to clean the trap; it was not too bad. I just don't understand why "burping" makes it flow just fine. It's like it's vapor-locked.
Re: hairy clog
Galen Vetterick
There should be some holes in the sink bowl just below the plunger. The sink overflow drains below the plunger to these holes. Many times soap and in my case shaving cream begins to plug these. Normally when the sink is draining it can draw air through the overflow and allow the drain to run faster. Sometimes you can also use a drain plunger on the drain with the sink full and be sure to put your other hand over the overflow. This can backflush the overflow holes too.
Besides hair on the stopper rod as other suggested. But I suspect the overflow holes not allowing air in.
This sink has no overflow drains
Dave Bair
I guess I'll replace the whole trap, drain, plug and plunger assembly.
Re: This sink has no overflow drains
Jason Roehl in Lafayette, IN
One reason it may be happening is that the plug doesn't raise high enough to let the drain "burp". I know mine does this, and if I quickly and firmly push the plunger down to raise the plug, it will burp and drain quickly. I've long thought I just need to add a little epoxy putty to the surface of the plug that contacts the actuator so that it raises just a bit more normally.
Jason
Galen Vetterick
It sounds like the trap is being siphoned dry. When you use the sink again then there is a large volumn of air that is trying to vent out the pop-up valve (upstream) before water can run downstream. With no overflow or hidden under the rim overflow there has got to be a way to opeate at atmospheric pressure. Is there a vent pipe for this drain? Could be it is resticted. If no vent pipe is there an air admittance valve upstream of the trap to let air in? Is it working?
I assume you reinstalled the the stopper with the notch to the back to get good pop-up lift. Sometimes someone pushes or pulls the lift rod too hard and the spring clip holding it to the pivot rod slips. You might re-adjust to get better stop lift. I still suspect improper air since you say once it purps it run OK.
Just think'n
Another possibility
Lee Schierer McKean, PA
Another possibility may be that there is no vent line on that drain or if there is it isn't properly configured. Improperly vented drains don't drain well and often siphon all the water out of the trap.
Lee
Re: Another possibility
Dave Bair
There are two vents for the main line, one on each end where the bathrooms are. Whats the best way to check them? I have a septic tank system, so I'd rather not pour gallons of water into the line.
Joseph Mulherin, sr
Dave, in the construction of the bathroom was there ever a vent installed above the waste?
This could be your problem at the waste/vent piping. Who built the bathroom?
Galen Vetterick
It's hard to second guess how your system in laid out. If the sink, tub and toilet are on the vent and how each may run to it. Septic systems do not always share the same vent run especially toilets. I've used a drain snake, a long rod or even a heavy bolt on a string to check a vent from the roof. The vent pipe should run vertical with no bends. well I have seen a couple of 45's to jog one over. You should not hit water unless system i sbacked up. Is your home one story and is there a basement? Is this the only drain acting this ways. I have seen a septic tank back up to where the level backs up into the vent high enough to not allow good draining but this usually effects other drains to (floor drains). clearwater from a sink can bybass a septic tank inlet or not depending on how old and how plumbed so hard to cover all ideas.
One thought was check valve to septic tank being held open and gas belching back but it should stink and happen to other drains.
The horizontal line on the sink could be half plugged if it has been allowed to run this way for a long time. The plunger on a full sink can help break this up past the trap Still guessing!
Dave Bair
Joseph: "was there ever a vent installed above the waste? "
Yes. I have one long waste line that is vented on each end.
"Who built the bathroom?"
The builder. I've replaced the sink and shower.
Dave Bair
Galen: My home is one-story with a basement. No other drains act this way. I'm positive that the septic is not backed up.
Joseph Mulherin, sr
Dave, venting the line at the ends is NOT the way to vent plumbing. The code I learned was that the vent had to be within 24" of the fixture. You could open the rear wall of the bathroom and install an air vent which has a spring/rubber built into it....sucking air in and closing when not venting... would just be a matter of patching the wall after installing one. Check with your plumbing supplier to see if they have one.
