PM2000 Dust Collection?
Derek Arita
I'm wondering how good the dust collection setup works in the PM2000? I know that a lot depends on the suction provided, but aside from that, is the routing of the dust, effective?
Re: PM2000 Dust Collection?
PM 66
Merle
Derek,
I have a PM 66 that does not have the 4" flex tubing going up to the blade so I can't give you any first hand experience. However, I imagine that feature makes a world of difference for the dust that stays below the table and may reduce the dust that comes off the top of the blade.
I also need a collector for the dust that comes off the top of the blade and use a SharkGuard for this.
HTH,
Merle
What I did:
DizD
I've had PM2000 for about 6 years. Several years ago I removed the interior hose, but not the blade shroud ( the hose is 3" dia. and I didn't like it necked down like that.) Then I cleaned and waxed the bottom of the saw cabinet and I have been using it like that. Still have to clean out cavity several times a year, mainly because of small strips that get caught around the opening. Dust collection does not seem to be any different without the hose.
Re: What I did:
Derek Arita
Why is that 3" not a 4"?
Re: What I did:
DizD
Don't know. What I understand about dust collectors is that they need large air volume to work correctly. The 4" outlet at the base reduced to 3" inside didn't make sense to me.
Re: What I did:
Derek Arita
Has anyone here run 4" all the way to the internal shroud?
