OT Stripping wall paper question
Anybody got a good way to strip wallpaper? We have been using water with a little dish soap. This stuff is coming off very slowly and a tiny little piece at the time. We have scarified The face with a Wallpaper "tiger" and in some cases pealed the face off it leaving only the fuzzy backing.
Re: OT Stripping wall paper question
Nat Robison
Buy the stuff that's called, um, wallpaper stripper. I think it's formulated to dissolve wallpaper glue far better than soap and water. The one time I used it, it removed all traces of paper and glue completely. Any Lowes or HD should carry a few brands.
Justin Szeliga
A vinegar solution was the answer in the old days. You may need to let the water get to the adhesive for a bit more time so it releases better & you'll get larger pieces.
The best ingredient for wallpaper stripping is patience.
Dave
Dave
I've stripped alot of wallpaper and I got a little tool thats fits in your palm. It has little wheels on it that perforates the paper so the water can soak behind the paper.
John McGaw (Bodger)
If the wall behind the paper was properly prepared before it was applied then more soaking time and one of the commercial strip preparations will probably do the job. The one I was using claimed to have some sort of enzymes which partially digested the glue to break it down. On the other hand, if somebody put paper up over unprimed drywall then you are in for a hellish time -- I had that in the foyer in this house and, despite the small size, it took two days of intense work to get it clean enough to paint.
james runchey
I used to use a pump-up sprayer with warm water and vinegar. Spray a section and let it soak for a half hour and respray yhe area so its nice and wet, then scrape. The secret is time, let the water work,
Jason Roehl in Lafayette, IN
You've heard pretty much all the tricks here. I've removed probably square MILES of the $@#!%$@# stuff, and I usually use an escalation method.
1. I try dry-peeling the paper. Sometimes you can peel off most/all of the paper this way, maybe the paper backing remains.
2. If the wallpaper is porous, I use a pump sprayer and keep soaking the paper with very hot water until it peels or scrapes pretty easily. Don't let it dry--you may have to do some "leapfrogging" once the paper is coming off. Soak ahead of where you're working and periodically re-spray what you're working. Patience is a virtue here.
3. If the wallpaper is not porous (as evidenced by the sprayed water not soaking in at all, or it's obvious), I use a Paper Tiger scoring tool. Light pressure is all that's necessary--too much pressure will damage the drywall, and you'll be fixing millions of score marks. The more scoring, the better. Once scored, the paper is now somewhat porous--see Step 2...
4. If the paper is still not releasing, I'll add in some DIF solution to the hot water, or just switch to the DIF gel. Again, patience and keep it wet.
5. Sometimes, the drywall paper comes too. Try not to curse too much.
6. Spread the word that wallpaper is a creation of Satan himself, birthed in the deepest pits of hell.
7. If someone absolutely insists on hanging wallpaper, paint the wall with semi-gloss paint first and use sizing (roll the glue on the wall AND the paper before hanging it). It will adhere just fine, but will still be easily removable when that time comes.
Jason
gary peterson
Hung paper professionally 5 yrs, also took off alot. Great advice from many readers. Let me hit some solid points. Remove the outer section, usually the vinyl comes off and paper remains. If does or not saturate with a wallpaper remover solution(Def here in nj) a smallish area say 4x4ft and wait...rewet and wait some more. while still wet lift an edge and should pull off. I would use those paper puncture things as a last resort, can wreck havoc on drywall. If the walls were prepped properly you should have an easy time. With the discontinuing of oil based primers, all is latex, which is water which when in contact with water can cause serious problems. If you can remove and have wall board damage, prime damaged areas with a shellac based primer, do that after the wallboard dries. Two coats is preferable.. Unless you remove all the old paste, any new paint will absorb the paste and give you crackling. Again, if you cannot use an oil based primer use the shellac based primer on dry wallboard...gotta seal the depapered wall. If you plan on repapering, do not use semi gloss , use a wall prep solution that is compatible with the paste. Or, leave the problem for the next person(just an old solution many crooks use) Got long winded but tried to cover all the bases without seeing the job. good luck, be patient.
Paul Blackwell
I'm surprised that no one mentioned a wallpaper steamer. We've had one for years, and lent it out many times. Works great.
Mark
Pro tip from a painter wallpapered was to use a water solution with fabric something like "Downey" Fabric Softner in Canada , not sure about US . Mix it up in a bucket maybe 70/30 water/ Fabric softner and then sponge on allowing it to soak in a bit as you scrap. Just keep wiping and saturating the wallpaper you want to remove and scraping off with a putty knife
Works GREAT
Re:Sell the house...
Bruce McCrory
.... and find one with no paper. And, definitely, no crazed checks in the poorly painted surface of walls.
It's easier to rip out drywall and start over.
Exactly.....
I want to sell it, That's why I am stripping the paper.
Re: Oooh.  So sorry...
Bruce McCrory
I was really trying to cheer you up. Humor, you know. Now, I feel horrible.
Our son spent his high school years sleeping in a room wrapped in tiny pink hearts. He's moved on, but the hearts are still there.
You'd be surprised how many wives (spouses) have standing orders: "No wall paper!"
Re: Exactly.....
Joseph Mulherin, sr
Barry, seems to me you are doing way too much remodeling on this house by trying to strip the wall paper....just buy some 1/4" drywall board and recover the entire wall surface and be done with it.
