Adhesive-back sandpaper
Doug in Utah
What grit would you recommend for use on a miter gauge board? Or is one grit as good as another?
Re: Adhesive-back sandpaper
Whatever grit with which you are comfortable.
Personally, for jigs and such, I prefer 100-150 grit. I feel the coarser grits are too coarse and the finer grits a bit fine.
I'm also cheap. I typically use contact cement or spray adhesive. I will sometimes use emery cloth as it is easier to peel off if need be.
I'm with JL on this. I use 120 mostly because it just feels right. I do thick courser grits leave marks on the wood. I have it on my push sticks for the jointer and use it on my miter gauge and several other homemade jigs for the table saw.
