OT - anybody know Larry the Cable Guy?
Joe in a Cleveland suburb
Does anybody know how the cable signal works for cable tv?
The cable from the cable company goes from the pole to my house where it goes into a box on the side of the house.
From that box (that contains a splitter) one cable goes on the outside of the house up to a bedroom where there is a jack.
The other cable goes from the box into my basement. In the basement, maybe 15 feet from the box/splitter outside, is another (cable company supplied) splitter.
This splitter goes from one to two. One cable goes to the kitchen tv, and the other cable goes to a splitter I put in many years ago.
Its all worked fine until the other day. I decided to run a cable from my splitter (bought at Radio Shack a long time ago) into my sunroom directly above the splitter. I used a 12' cable purchased from Lowes.
I pulled it up through a hole I drilled in the floor behind the base board to the tv. Hooked up the tv and no signal. I tried a couple different tv's - hook up the
cable, use the scan option on the tv, and get nothing. Tried the same tv's at different cable locations, works fine.
I thought maybe the cable was bad. Tried several different cables. No luck. Thought the splitter went bad, bought a new one, no luck. What the heck
is going on? Tried different ports on the splitter(s). No luck.
Is there any way to test the signal or something without the fancy testers the cable guys use? It's as if this sunroom has some super power not allowing
cable signal into it.
My tv, phone, and Internet all work off this cable.
I might just have to give in and call the cable guy...
Thanks for any suggestions!
