Re-cycling Solvents?
tom
When I use MS I will dump in a container to let it settle out then pour off the top portion. Has anyone done this with shelaac thinner/ denatured alcohol?
tom
Re: Re-cycling Solvents?
Depends on what you mean by recycle.
I let all my solvents, thinners, etc. settle out in my glass jars. After they settle and harden, they get poured off into my cleaning jars.
I never use them to thin, I just use them as the initial cleaning solvents for my brushes.
I wouldn't expect shellac to settle out quite the same way; but don't know. I'd say, give it a shot and see what you learn.
Kneale Brownson
We use denatured alcohol to clean up our knitting machines. Let the stuff settle out in glass jars and then run through a filter. Reuse for cleaning. Never use the used stuff for any other purpose.
Dick Coers
You might see some settling with regular shellac, but if it is dewaxed, you are going to wait a long time. I think it will get thicker over time as the denatured evaporates, but will never really settle out.
